20 Most Recent Sony RM-ASP001 Remote Control Questions & Answers
Tune AM radio to 600 and turn up volume. Place remote nest to antenna and press every button. Each one should cause radio to emit sound. If button does not emit sound that portion of remote is fubar. And you can get the remote for the changer for lot less than 30 bucks Go to attached link 50results for dvp cx995v
Sony RM-ASP001... | Answered on Sep 04, 2017
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Sony RM-ASP001... | Answered on Nov 09, 2015
Since the symptoms have changed with replaced parts, I would suggest putting your old parts back in and see if the original symptom returns. If, when you put your old parts back in the colored vertical lines come back, then the most likely issue is one of the replacement parts is bad.
Sony Televison &... | Answered on Oct 26, 2020
Yes, It should be. You might need to connect it with a USB wire instead of a HDMI lead. You can the access it through the input button on the remote. The button will probably be in the top left corner of the remote, level with the power button, ( marked with a square with an arrow pointing into it).
Sony Televison &... | Answered on Oct 25, 2020
Use Photo Sharing Plus to Display Photos, Videos, and Songs on Your TV
  1. On the supplied remote, press the HOME button.
  2. Select Settings.
  3. Select System Settings.
  4. Under System Settings category, select Set-up.
  5. Under Set-up category, select Network.
  6. Under Network category, select Renderer Function.
  7. Select On.
Feb 27, 2019
Use Photo Sharing Plus to Display Photos, Videos, and ... - Sony
5 Easy Ways to View Photos on Your TV - Techlicious
www.techlicious.com > tip > 5-easy-ways-to-view-your...
Mar 21, 2019 - If you have a smart TV, you can use a photo viewing app to access ... I think I'm caught in between *real* smart tv's and this sony bravia one :(.
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Sony Televison &... | Answered on Oct 13, 2020
possible control board overheating or video board look for capacitors swelling on boards
Sony Televison &... | Answered on Sep 19, 2020
3 blinks is a error code "lamp door not properly closed" but what it really means is the lamp door is warped from heat from the lamp.
The door if removed has a plastic peg on its back side-the peg when door is in place engages a tiny lever behind it----
What to do?
Remove door and engage the lever with something not metal==turn set on and if it comes on you know the door is the issue.
DO NOT LOOK DIRECTLY AT THE LAMP- DO NOT OPERATE SET PROLONGED TIME WITH DOOR REMOVED OR COVERED WITH ANYTHING ELSE==THIS IS ONLY TO SEE IF THE DOOR AND SWITCH ARE YOUR PROBLEM.
SD TECH
Sony Televison &... | Answered on Sep 16, 2020
An almost complete guess that you are feeding digital into a tv that is incapable of processing it.
HDMI is digital only and an adaptor lead won't convert the signal to analogue. Digital to analogue converters are available but how successful they are I have no experience...
Sony Televison &... | Answered on Sep 10, 2020
Televison & Video Logo
12 questions posted
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony rm asp001 400 disk changer stopped
  • Televison & Video
