20 Most Recent Volfenhag ZX-8100 Car Audio Amplifier Questions & Answers
Does the remote bass control have to be hooked up on a volfenhag zx-8100 for it to work
No, it's only use to control the gain or level from zero to what u set it to
7/16/2015 9:34:55 AM • Volfenhag... • Answered on Jul 16, 2015
Zx-8100 amplifier is red lighting.
try wiring them differently. here is a link for u to go to http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html . once there find your amp configuration (ie. mono, or 2 channel) then down to the type of subs an how many subs ( ie. 2 dvc (dual voice coil) 4 ohm subs) an that will show u how the subs should be wired and wired to the amp.
4/4/2010 4:21:40 AM • Volfenhag... • Answered on Apr 04, 2010
Whats the wiring diagram on a volfenhag zx - 2000
Request the diagram from Volfenhag.
3/23/2021 3:13:26 AM • Volfenhag Car... • Answered on Mar 23, 2021
Can my 12 volfenhag be fixed if it's blown
Sure. If you want to spend about $100 on a recon kit. Honestly volfenhag is a flea market brand and not worth fixing.
11/4/2016 12:51:25 PM • Volfenhag Car... • Answered on Nov 04, 2016
VOLFENHAG ZX 7170 4 channel 100 watt wiring diagrams
How to wire amp?
9/1/2016 4:01:37 AM • Volfenhag Car... • Answered on Sep 01, 2016
Wiring a volfenhag zx 7170 4 channel amp
What subs/spks do u have? How many?
9/1/2016 3:53:57 AM • Volfenhag Car... • Answered on Sep 01, 2016
I have a 2000 w volfenhag amp and a 15 in cadence 350/600 rms watt sub, what gauge wire should i use?
I would use a 4 gauge wire for the power supply to the amp and a 4 gauge neg of the amp
8/6/2016 4:51:31 AM • Volfenhag Car... • Answered on Aug 06, 2016
Can I buy a rebuild kit for a Volfenhag 12 it is the 2500W version of the ZX-4812DVX. I need a new top everything else works I believe?
try looking for mfg name, place where they were made, state or country, zip code, part numbers, any information here is a website that may help: www.alltheinternet.com/ www.thesearchenginelist.com/ www.infolinks.com/ www.searchfiles.org www.wikipedia.org/ www.wiki.org/ www.hackipedia.org/ /rebuild power inverters 2500 watts /volfenhag 12 manufacture+service+rebuild /repair+fix ZX-4812DVX
7/15/2016 4:33:34 AM • Volfenhag Car... • Answered on Jul 15, 2016
Mounting amp to car
make sure you mount where you can get a good ground and where it can get enough air to keep cool. underneath the car seat is where a lot of installer put the amp, and if you are going power up a lot i would think about mounting a fan to blow air on it to keep it cool. i have fans connected to my laptop power supply transformer to keep the unit cool, here other ideas you will never be told, putting little holes around power supple, fan area, any where there a lot of heat is generated the air flow helps it stay cooler while powering up the amp. good luck and be safe rod
4/23/2015 8:46:13 PM • Volfenhag Car... • Answered on Apr 23, 2015
Protect light come on
stop using the unit, it may blow up or start a fire.
4/23/2015 8:08:11 PM • Volfenhag Car... • Answered on Apr 23, 2015
Boss blade 1600 watt amp protect light come on
if the protection light came on even though you was not powered up means there maybe a internal issue with the unit, i would be careful with that unit.
4/23/2015 8:07:13 PM • Volfenhag Car... • Answered on Apr 23, 2015
Volfenhag ZX-8100 Car Audio Amplifier Logo
3 questions posted
Top Volfenhag Car Audio & Video Experts
 Francisco Mauricio...
Morne Olivier
Morne Olivier
Pierre Laplante
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Volfenhag Car Audio & Video
Most Popular Question
remote bass control hooked up volfenhag
  • Car Audio & Video
