20 Most Recent
Konica Minolta Konica Kit For Bizhub Press C7000 350k And C6000 300k Dadupm3500 Questions & Answers
Codigo de error
This going to take a while, open both front doors do not pull out the lower section your, going to pull out the upper middle section. then from the right side (WHAT EVER YOU DO NOT LEAN / HOLD ANY ONE OF THOSE FOUR SHAFTS!!!!!!!!!!!!!!! THAT WILL CAUSE MAJOR TROUBLE! Now reach in and you will see a small assy. which is across from the transfer belt on the other side of the unit you just pulled out. On the assy. are three sensors each covered by a metal cover with a dry rag ensure no static electric can destroy the sensors. clean all three, be careful each has a small spring do not let them fall inside the machine. If you want to or have to remove that assy. there are two screws and once connector all the way in the back (DO NOT LEAN ON THOSE SHAFTS!!!!!!!!!!!) don't let the screws drop! Once done remove the transfer belt, and clean the transfer belt cleaning blade system, then run gamma, and color checks in 36 Mode. GOT IT! Better have a tech come out. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
C-2813 error code in c-6000 help us
2813...related to cyan.
Excess charge on drum beyond the specified value.
Solutions...1) swap the drps board with yellow or with other color unit and see weather code is changing .if it is changing the drps board is the culprit.
2) clean the HV contacts located behind the processor unit.
3)clean the IDC Sensor unit
4)change developer
5)caronas
Konica minolta bizhub 7000 controller doesn't turn on
manuals.
konicaminolta.eu/
bizhub-C554-C454-C364.../id10-0061.html
bizhub C554 C454 C364 C284 C224 ... The Main Power Switch of the machine and thePower key on the Control Panel. No. Name, Description. 1. Main Power Switch. Press this switch when turning on or off the main power of this machine or ...
myworks.sindoh.com/upload2/.../d37800822888835787371.pdf
KONICA MINOLTA Confidential. 2. C-2721, Intermediate .... v) Execute Printercontroller calibration for every output profile. (Standard ..... Start CWS5 and login to a Fiery controller. ii) Click [Calibrate] ...... If FD skew doesn't remain,. FD skew ......*A1DURX01: For bizhub PRESS C7000/C6000 and bizhub PRO C6501. 2.
How to fix 2231 error code?
Could be one of these, start first with the Y drum
Anything else get a tech out power supplies and printer control boards are serious money$$$$$$$$$$$$$$$
• Printer control board
(PRCB)
• Drum motor /Y (M14)
• Encoder sensor /Y1
(PS81), /Y2 (PS82)
• DC power supply /2
(DCPS2)
• Drum Unit /Y Btw, I’m available to help over the phone in case u need at
Konica c7000
Try cleaning the corona wire housing by disassembling it and washing it with dish washing liquid, or replace it with new. or maybe you got the wrong corona wire. or maybe try to install it the right tightness.
Error code c2801
Maximum density correction problem.Clean the AIDC sensor located under OPC drum.
