20 Most Recent Sony RM-Y916 Remote Control Questions & Answers
It is possible that this remote will not program to your Comcast dvr. Your DVR is probably newer than the remote and has new codes that the remote doesn't support. The only thing you can do now, is either purchase a new universal remote that supports both units. or use your Comcast remote to program it to your TV. the Comcast remotes are programmable.
Sony RM-Y916... | Answered on Dec 11, 2018
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
Sony RM-Y916... | Answered on Mar 31, 2013
Split screen means 2 pictures side by side--one is ok or both are bad?
Sony RM-Y916... | Answered on Apr 03, 2012
1080P is a resolution, not a model number. Coby has no universal remote codes for any of its products
Sony RM-Y916... | Answered on Jun 04, 2010
just go here and choose the type of device and brand to get the code
then the instruction are towards the bottom of the page
electech
Sony RM-Y916... | Answered on Nov 30, 2008
First turn on device to be programmed. Press what device you want to program (tv) hold it down and at the same time hold power button down. Wait for red light to shut off and come back on. When light comes on remove finger device button and continue to hit power button on & off until device shuts off. Then hit stop button on the bottom off remote.
Sony Televison &... | Answered on Aug 04, 2020
Take it to a Sony Service Centre to save your money and get it fixed properly.
Sony Televison &... | Answered on Jul 20, 2020
If the screen of your TV is black and nothing is displayed, see the FAQ below: No picture on the TV screen.
When using a TV with the Self Diagnostics option, try the Self Diagnostics test. For details, refer to the following Q&A: How to use the Self Diagnostics option.
Sony Televison &... | Answered on Jul 13, 2020
Are you a television engineer? Do you have all the test equipment? Normal people can't repair their own televisions. Do you know that the main board you put in was a good one and not out of a scrapped set? Can you send it back and ask for another one? Taking it to a television engineer is by far the cheapest way to fix. Or you can change all the boards, but make sure you buy them from the manufacturer and not Jimmy. Change all the boards before you turn on the power to avoid 'domino effect', one bad board kills all the other boards attached to it.
Sony Televison &... | Answered on Jul 09, 2020
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sony Televison &... | Answered on Jul 01, 2020
Hello
Blu-Ray players' region hack proceedings are yet to come.
Sony Televison &... | Answered on Jun 24, 2020
It won't work as it has a different size screen and will produce the wrong size picture, if it works at all.
Sony Televison &... | Answered on Jun 19, 2020
Televison & Video Logo
13 questions posted
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
muy buenas alguien conoce los codigos
  • Televison & Video
