20 Most Recent Cisco 7941G-GE IP Phone Questions & Answers
Complete these steps:
  1. Unplug the power cable from the phone, and then plug in the cable again.
  2. Immediately press and hold # and while the Headset, Mute, and Speaker buttons begin to flash in sequence, release #. ...
  3. Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash.
Cisco 7941G-GE... | Answered on Sep 16, 2015
what is you bandend system?
Cisco 7941G-GE... | Answered on Apr 25, 2014
reinstall it and use it and enjoy
Cisco 7941G-GE... | Answered on Dec 05, 2012
These phones can take their power from a Power over Ethernet switch, where all you need to do is plug the phone in to the switch and it gets its power from there.
You can also get power cubes for these phones, but they do not come with the phone as standard, as most people like the convenience of having the power coming from the switch, and not needing to use up a further power socket in the floor/wall.
Hope that this helps!
I would check your duplex settings. Often, if you hard code the duplex settings or have a mis-match; one end may not talk properly. Also, have you tested the wiring? Do you know the ethernet is okay for sure? TechRx, Inc. - techrxgb.com
Cisco 7941G-GE... | Answered on Aug 27, 2010
hit "9" before dialing a number.
If you are sure your network is setup properly; and the voice vlan is properly setup; it's probably a bad phone. You could try cisco TAC for support. I would double check that the MAC address of this particular phone is correct with the bootup provider.
Control Panel>Add/Remove Programs>Dell Control Point System Manager
select change> next> click modify> Internal Network Card Power under Power Manager> “This feature will not be available”
Cisco 7941G-GE... | Answered on Mar 02, 2010
This can be caused by corrupted firmware, or possibly damaged circuitry. IdacomUSA is your best bet. Your phone will be completely refurbished, and sent back to you within two weeks and comes with a 2 Year Warranty on the phone.
Cisco 7941G-GE... | Answered on May 13, 2009
Unfortunately this is a very common problem with Cisco's IP Phones. It can be caused by either a faulty hookswitch or a damaged jack. Both of these problems can be remedied by contacting IdacomUSA.
Try configuring CCM IP address either trough DHCP parameter, or Network configuration on the phone.
Cisco 7941G-GE... | Answered on Mar 19, 2009
dear,
go to ccm->service parameters-> cisco extension mobility-> alpha numeric-> true.
Cisco 7941G-GE... | Answered on Dec 29, 2007
the first problem will be to check or replace the cable that you use to connect the phone or check the jack that you use
Cisco 7941G-GE... | Answered on Jul 12, 2007
    these are the popular firewall for recent days:
    ·Packet filtering firewall
    ·Circuit-level gateway
    ·Stateful inspection firewall
    ·Application-level gateway (aka proxy firewall)
    ·Next-generation firewall
Cisco Computers... | Answered on May 28, 2020
  • Packet filtering - ...
  • Stateful filtering - ...
  • Routing support - ...
  • Transparent firewall - ...
  • AAA support - ...
  • VPN support - ...
  • Supports IPv6 - ...
  • VPN load Balancing -
Cisco Computers... | Answered on May 13, 2020
DO NOT CALL FAKE NUMBERS OR GO TO FAKE WEBSITES. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you. Please only ever use the support contacts from the official company website.
Cisco Computers... | Answered on Oct 21, 2019
Su mensaje no califica como una pregunta o consulta para un problema, intente en otro lugar
NO HAGA ESTE SITIO CON SU BASURA
Lleve su BASURA a otro lado
Su mensaje califica como SPAM
Cisco Computers... | Answered on Oct 20, 2019
Cisco 7941G-GE IP Phone Logo
Popular Tags
25 questions posted
Top Cisco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Jax Planet
Jax Planet
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Cisco Computers & Internet
Most Popular Question
need modify settings cisco ip phone 7941
  • Computers & Internet
