20 Most Recent Danby DAR482BL Compact Refrigerator : black all fridge 4.4 cu ft Questions & Answers
That cup, or the hose that it leads to, out the back and down to the bottom is plugged. It has to be cleaned out so that when the freezer automatically defrosts, the water will run into the cup and down the hose to evaporate in the tray under the compresser. You should be able to pull that cup off to clean it. The hose is a little awkward to get to , but if you cdan blow through it, everything should good.
Danby DAR482BL... | Answered on May 10, 2011
It looks like this unit is discontinued.
You can get an approximate idea of the cu. ft. by measuring the inside dimensions (h x w x depth) in inches, multiply them together, and divide by 1728.
As for the noise, it could be the condensor fan rubbing on the fan shroud (if the noise is outside of the box) the evaporator fan rubbing the fan shroud inside the box, or any number of other things.
Danby DAR482BL... | Answered on Jan 16, 2009
Turn off the refrigerator and remove the power cord from the wall socket.
Unscrew the thermostat / dial and gently pull it out of it's holder....
There is a tiny pipe on the back of the thermostat / dial.
Gently pull that tube out of the pipe that it is in.
The most likely reason for the lack of cooling is that there is a layer of gunk on that tube.
Take coarse cloth or pot scrubber and clean that tube gently...
Replace the tube in the pipe and see if refrigerator runs properly....
If not, new refrigerator needed....
Regards
Geoff
Danby... | Answered on Jan 06, 2020
The tray is located inside the toe panel at the bottom. Remove the tray carefully for cleaning as it will be full of disgusting effluent.
Danby... | Answered on Oct 31, 2019
Check the heater behind the panel in the freezer.I unplugged mine checked it and it seemed fine plugged back in .no more issues
Danby... | Answered on Jun 30, 2019
the list of causes --- yes on bad compressor will cause failure --as well as thermo safety -thermostat --low no freon --dirty condenser -fan failure --circuit failure -are a few
Danby... | Answered on May 09, 2019
hi before you may damage
install a new fan this can solve your problem
Danby... | Answered on May 01, 2019
Refrigerators Logo
9 questions posted
Top Danby Refrigerators Experts
William Miller
William Miller
Marvin
Marvin
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Danby Refrigerators
  • Danby Refrigerators
Most Popular Question
ge concept ii fridge leaks inside fridge
  • Refrigerators
