20 Most Recent
Kodak ESP C315 Wireless All-in-One Printer Questions & Answers
The ink is blurred and not printing all the colors
Hi, You could try cleaning the print heads with a damp paper towel. Gently dab at them until you see clear colors with no bleed. It's ok even to let the damp paper set on head for few minutes. Also clean the print area in printer. Then put cartridges back in printer and run a print head cleaning. You may have to run it a couple times.
this has worked for me unless of course a cartridge is empty of a color.
Good Luck to you, I know you can do it,
tina
My printer is not printing black only colours
there must not be as same as you are saying but it may perhaps happen that, live cartridge doesnt perform due to improper heating of that printer. its heating mechanism may have failed, go to its care center and get treated...
My kodak verite 55 printer says it is out of paper, but it is not. It also says the printer is not recognized. Any ideas?
- Check to make sure that the paper tray is loaded correctly and that the paper is not jammed in the printer.
- Make sure that the paper guides in the tray are adjusted correctly for the size of paper you are using.
- Check to see if the printer driver is up to date. Outdated printer drivers may cause the printer to not be recognized by the computer. You can download the latest driver from the Kodak website.
- Check the USB cable that connects the printer to the computer to ensure that it is properly connected and that there is no damage to the cable.
- Restart the printer and the computer and try to print again.
- If the issue persist, run the printer troubleshooter, it might help you to identify and fix the problem.
- If none of the above solutions work, it is possible that the printer's paper sensor is malfunctioning. In this case, contact Kodak customer service for further assistance.
It's important to follow the instructions carefully and if you have any doubts or difficulties, consult the printer's user manual or contact the manufacturer for assistance.
