20 Most Recent Sanyo DS27224 TV Questions & Answers
36" Sanyo Tv
My television has wavy lines running from corner to corner it is due to power supply fileration is not proper. this might be due to your main filter capacitor.please take the help of tech person. Is this fixable or time for new one. it is fixable & not a major problem. no need to buy new one. good luck.
10/11/2007 7:18:21 PM • Sanyo DS27224 TV • Answered on Oct 11, 2007
Get stuck dvd tape out of sanyo dvw 7200
DVD ... Tape ... I wonder which one.
12/6/2022 10:27:04 PM • Sanyo Televison... • Answered 3 days ago
2answers
My sanyo tv keeps changing channels and input settings and the volume also goes up and sown with UT
Try unhooking the cable going to the selector buttons on the TV and see if it work ok with the remote, if it does the button cluster needs replacing, if it acts the same replace the main
12/4/2022 10:10:26 PM • Sanyo Televison... • Answered on Dec 04, 2022
How to program a sanyo vizon no tv
Question makes no sense. If you have 'no tv' you can't program it. https://www.google.com/search?q=program+a+sanyo+vizon ..
12/3/2022 4:27:13 AM • Sanyo Televison... • Answered on Dec 03, 2022
Fixing a 42 Sanyo tv, model# DP42D23
Thanks for the good article. I hope to see you with a better article than the one I am writing now. Thank you again :)
11/20/2022 7:21:14 PM • Sanyo Televison... • Answered on Nov 20, 2022
I have a white screen on my sanyo tv
Try unplugging your TV for about 10 minutes and also hold the power button on the TV for about one minute and then plug your TV back in again and turn it on to see if the white screen is still showing up again. It could be the capacitors inside of the TV have gone bad or the powerboard is not working.Check the cables and the connections to your TV to make sure they are fully connected. Or the TV connections are bad and should be replaced.
11/13/2022 7:27:17 AM • Sanyo Televison... • Answered on Nov 13, 2022
How to fix volume on a Sanyo DP50842 television please?
Buy a new remote for it and stop using the buttons on the television! They are $20. https://www.google.com/search?q=sanyo+dp50842+remote+replacement .
11/12/2022 3:05:25 AM • Sanyo Televison... • Answered on Nov 12, 2022
2answers
I have A Sanyo DP26746 TV with what looks like a burnt mark smudge rite in the middle of the screen the size of a golf ball, any idea what is wrong
Hi, it's sounds like a group of the screens leds have overheated and/or burned out. If you just got the tv, this would be strange. However if you've owned it for years, then this might happen. Please attempt one power cycle and then flip through channels to see if the issue remains. If so, you might need to set a tv diagnostic-appointment with a company like geeksquad/ home depot after attempting a factory reset on the tv. Thank you.
11/11/2022 1:54:06 AM • Sanyo Televison... • Answered on Nov 11, 2022
Sanyo DP32648 - 31.5" LCD TV screen goes black with sound, turns off/on then works for several minutes.
Question edited for full 'make model (what it is)'. Question moved to Sanyo. Could be the power supply, it could be the main board. My advice regarding home television repair, unless our Television Expert Larry comes along. https://www.fixya.com/support/r29790007-repairing_own_television ..
11/4/2022 6:02:31 PM • Sanyo Televison... • Answered on Nov 04, 2022
How can I get rid of pop up showing on the screen from my 32 inch sanyo tv?
go into picture settings and turn it off
10/15/2022 6:00:22 PM • Sanyo Televison... • Answered on Oct 15, 2022
2answers
Sanyo 55 in tv comes on goes back off no channel registered
Is it attached to the aerial/cable socket.? If it is, then the main control board has probably failed.? Changing it out is a fiddly but achievable job, but it's probably only worth it if you can pickup a used replacement part from eBay or similar.? Otherwise a brand new replacement board may be up to $150.?
10/13/2022 10:47:55 PM • Sanyo Televison... • Answered on Oct 13, 2022
My sanyo tv looks like it's on acid when it comes on
Hi, Please adjust your tv's contrast and brightness to try an overcome the issue. If there are accessories linked to your tv, please temporarily remove those accessories and restart your tv to see if the issue goes away. If all else fails, a factory reset would be the next option. Thank you.
10/13/2022 1:52:15 AM • Sanyo Televison... • Answered on Oct 13, 2022
Televison & Video Logo
Popular Tags
7 questions posted
Top Sanyo Televison & Video Experts
Jaime Hernandez
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
36 sanyo tv
  • Televison & Video
