20 Most Recent Philips Magnavox 27MT5405 TV Questions & Answers
The picture is out of focus for all inputs.
the tv is not worth fixing,get a flat screen lcd hdtv,here is the manual, Philips Magnavox 27MT5405 Product Manual
5/8/2015 6:17:13 PM • Philips Magnavox... • Answered on May 08, 2015
2answers
Hooking up dvd
Brad, AV-1 INPUT, be advised this will use up the AV1 port so if you have another item that uses regular AV cables you`ll then have to use AV2 for the video in and L&R audio in, enjoy, BMW Rider
2/24/2012 10:12:26 AM • Philips Magnavox... • Answered on Feb 24, 2012
Magnavox tv about 11 years old does not turn on at
Magnavox are a generally cheap brand of television so 11 years out of the product is a good run
i would assume that the power supply inside the Tv has died, you could probably get it repaired, but it would be most likely cheaper just to buy a new TV.
3/5/2011 4:31:01 PM • Philips Magnavox... • Answered on Mar 05, 2011
I lost the code for
if you got a pc go online search for a code,hope this help
3/3/2010 4:08:42 PM • Philips Magnavox... • Answered on Mar 03, 2010
Picture does not stay on when set is turned on
its a switch fault, you need to get a tecnition but cheaper buying a new tv,hope this help
3/3/2010 4:07:43 PM • Philips Magnavox... • Answered on Mar 03, 2010
TOP OF TV SCREEN HAS RED, BLUE, AND GREEN LINE
looks like it is the cable co faults,wait a few days then ask them to send a tecniction to check your problem,hope this help
3/3/2010 4:04:16 PM • Philips Magnavox... • Answered on Mar 03, 2010
Have a two inch black bar at the top of the
the electron gun in the CRT is not aligned well.
Align it.or maybe the the e- are not hitting that part of the screen
1/9/2010 3:31:04 PM • Philips Magnavox... • Answered on Jan 09, 2010
Wide black area top of the screen.
More than likely it's not the crt. If the picture has "foldover" at the top of where the picture is currently, then more than likely there are bad caps. in the vertical scan circuit. If not, the vertical sizing probably just needs to be adjusted. You will have to get in to the service menu to do that.
12/30/2008 6:56:46 AM • Philips Magnavox... • Answered on Dec 30, 2008
Horizontal lines after power on, then shutdown
No Worries...try me again sometime....T.
8/12/2008 9:28:01 PM • Philips Magnavox... • Answered on Aug 12, 2008
Philips Magnavox 27MT5405 TV problem with color
hi sir that thing hapen when the magnetic field around the screen is varies evry time the tv set is switched off then on after an hour may be , it comes to its normal magnetic field state and when not so there are two reasons 1- check for around the tv for any magnetic items ,speakers , cassette recorder or any magnetic motors clear the around electric items if not working after an hour of reset then refer to 2 2- there is an electronic element inside calles PTC it should be deffect it is a small three legs element and is giving the first power to the colis around the screen to make proper magnetic field check it by qualified person please please don't forget to rate the solution and remember i am here at your service regards ]
5/8/2007 4:31:56 AM • Philips Magnavox... • Answered on May 08, 2007
Need help connecting a playstation.
purchase an AV Scart Hub (a switching box/scart box),and connect all of your devices to your tv directly.
4/25/2007 1:55:10 PM • Philips Magnavox... • Answered on Apr 25, 2007
Why my TV is switching off by itself PHILIPS?
It could be a lot of things causing the issue, without electronic knowledge it's going to be hard to diagnose, also a 10 plus year old set isn't worth fixing, parts will run more than the set is worth, time for a new set.
11/28/2022 3:43:55 AM • Philips... • Answered on Nov 28, 2022
Philips 25HT2212 Crt tv no sound&.Service option code plse?
The inbuilt speakers are either broken or not working on your TV or the audio amplifiers are missing the supply voltage or the IC audio is not working anymore with your TV or there is an issue with the TV's capacitors.
11/26/2022 11:04:31 AM • Philips... • Answered on Nov 26, 2022
I need service option for Philips crt tv 25HT2212 ??
Click the link and it will find a service centre near you. https://www.google.com/search?q=Philips+crt+tv+25HT2212+service+centre+near+me ..
11/26/2022 5:16:36 AM • Philips... • Answered on Nov 26, 2022
I need a code for Philips CCR600 car DVD.
This is the three ways to get a code. https://www.fixya.com/support/r29874205-need_vehicle_radio_code ..
11/20/2022 10:25:14 PM • Philips... • Answered on Nov 20, 2022
21PT3461D /94R model philips 21inch tv fly back transformer number please help you
5445 2422 531 02475 Obsolete!
11/19/2022 4:33:06 PM • Philips... • Answered on Nov 19, 2022
2answers
How do i zoom out of a philips tv in model 32PFL3504D/F7 without a remote control
Buy a cheap Universal Remote and then you can select the screen format mode
10/25/2022 7:01:55 PM • Philips... • Answered on Oct 25, 2022
NECESSITO CODIGO PARA REMORE CONTROL CHUNGHOP RM139 EX PARA USAR EM TV PHILIPS
English only on Fixya. Philips TV remote codes. If you have recently bought a universal remote control and you need the remote codes to operate your Philips TV, we have codes below for your TV that should be working. If the first does not work keep trying the numbers down the list. Philips HDTV CODES 1129 1236 1237 1239 1261 1334 1351 1390 1411 Philips TV Codes 1004 1007 1011 1017 1018 1047 1053 1056 1057 1059
10/9/2022 5:20:24 PM • Philips... • Answered on Oct 09, 2022
Philips Magnavox 27MT5405 TV Logo
16 questions posted
Top Philips Televison & Video Experts
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
magnavox tv about 11 years old not turn
  • Televison & Video
