20 Most Recent Philips 32MT3305 TV Questions & Answers
Philips Magnavox 32MT3305 keeps shutting
the relay is the safety protective device..sometimes a defective component or something. maybe an overloaded power supply might caused this problem..so before any thing could gets worst..the relay will shut the unit..
7/21/2011 3:50:53 AM • Philips 32MT3305... • Answered on Jul 21, 2011
Instruction to replace fuse
The internal main A/C fuse is usually located within close proximity to the power cord entry point on the main PCB. So remove the back cover and follow the cord to something that looks like this.
11/6/2009 1:26:32 PM • Philips 32MT3305... • Answered on Nov 06, 2009
2answers
Keeps turning off.
may be the sleeping mode is enabled and activated for every 5 min.. so better check the sleepin mode is disabled to fix the problem.
12/5/2008 5:15:23 AM • Philips 32MT3305... • Answered on Dec 05, 2008
Vertical lines Philips TV
New tv
10/14/2021 9:30:05 PM • Philips... • Answered 23 hours ago
2answers
Where can i get a manual for philips RC1124008/01B?
Google or call Philips directly?
9/26/2021 7:55:16 PM • Philips... • Answered on Sep 26, 2021
2answers
Is there something wrong with the power supply board?
The power supply for your TV has stopped working and it would be more easier and cheaper to purchase a new TV than to try and fix the TV that you have that is broken. LCD and digital TV"s don't last as long like their CRT TV cousins do on the other hand.
9/19/2021 6:47:36 PM • Philips... • Answered on Sep 19, 2021
I have a 55in Philips flat screen the light blinks 6 times and the screen lights up but no picture
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://homenol.blogspot.com/ https://elektrotricks.blogspot.com/ http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name of your set, in its search box at the right column. View it on a desktop or in web View by mobile. Mobile view has no search box. Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
9/14/2021 12:41:44 PM • Philips... • Answered on Sep 14, 2021
Driver for Philips SP520 video processor
Only available from the manufacturer; Philips.com, if still available and not out of date.
9/8/2021 8:41:32 AM • Philips... • Answered on Sep 08, 2021
3answers
Wrong region DVD player won't play a disc
Can,t be done with the one you have,
9/6/2021 12:36:03 PM • Philips... • Answered on Sep 06, 2021
Westinghouse Sk-26h730s black, code to progr with old Philips universal remote
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. All the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check these sites too. http://remotesearch.blogspot.com/ https://elektrotricks.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops; as well as online shops. Visit the sites by Desktop computer and type in the brand name of your device in the search box at the right column. It will help you find the remote you have to buy. Mobille view has no search
8/30/2021 2:39:45 PM • Philips... • Answered on Aug 30, 2021
How fix a philips flat tv lcd with the screen glue to first installation without responding to command
Are you using a factory remote?
8/14/2021 4:15:58 PM • Philips... • Answered on Aug 14, 2021
2answers
Philips HTS3455/98 System NO SOUND
PCBoards are not a stocked item because PCBoards do not fail. Bad 'servicing' or missuse cause them to fail. They are not stocked as a spares item. You will probably have to either repair it or purchase a scrap unit and use that as a donor.
7/9/2021 8:55:00 AM • Philips... • Answered on Jul 09, 2021
Philips 32PFS6402/12 - no image but audio works!
You have the right idea in diagnosing, and the most likely reasons would be the board that drives the LEDs or the LED strips themselves. You have audio, and you have a picture, but you can't see it unless you use a light. Everything points to what supplies the television with light. Power board is okay, mainboard is okay. Here is a cautionary tale, written after seeing so many disheartening DIY stories on this site. https://www.fixya.com/support/r29790007-repairing_own_television ..
6/20/2021 5:46:00 PM • Philips... • Answered on Jun 20, 2021
Philips MC235B door shuts after about 3 seconds and has a whirling sound when its opened.
The cd is in the front. Is the cd turning creating the whirling sound? Does the unit have any lights on by chance?
5/12/2021 2:58:44 PM • Philips... • Answered on May 12, 2021
How to change input on philips tv
HelloIf the tV has a "Menu" button at tis fron panel, you can press it and surf through, come to input selector window, and can change the input to TV. If there is no Menu button on its front panel, there is no other way to change the inputs without its remote control.
5/4/2021 5:18:49 AM • Philips... • Answered on May 04, 2021
I have a Philips 42-in TV whenever I answer my model number or serial number to locate a universal remote control, it says invalid. Please help. Thank you.
Don't buy a Universal remote, no one does that any longer. You buy a facsimile remote, an exact copy, the same as the original. https://www.google.com/search?q=Philips+42%22+replacement+remote ..
4/20/2021 10:35:32 PM • Philips... • Answered on Apr 20, 2021
Code for dynex tv-DX32L221A12. I HAVE PHILIPS REMOTE,UNIVERSAL
Try 606 or 616 one of those should work.
3/6/2021 4:22:33 AM • Philips... • Answered on Mar 06, 2021
Philips 32MT3305 TV Logo
5 questions posted
Top Philips Televison & Video Experts
 Francisco Mauricio...
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
philips magnavox 32mt3305 keeps shutting
  • Televison & Video
