20 Most Recent
Philips 27MT3305 27" TV Questions & Answers
Shuts Off Immediately
Does the TV shut off if a signal from the scart is selected?
Philips sets have an annoying habit of going into standby after a very short time if there is no video for the synchronising circuits to lock onto. I find this a nuisance when I am searching for a signal from satelites when you move the dish.
By quickly changing channels you are resetting the shut down circuit.
This must be a time-out circuit controlled by a capacitor charging (I suspect) which has gone low in value, probably electrolytic. Replacing the capacitor should solve the problem.
Lines at top of screen
I have seen issues with complaints of raster with vertical retrace lines at the top of the picture and capacitor 2494 needs to be removed.
I want to collect tv schematic diagrams
You can simply do a search online for anything. Start with Howard W. Sams AKA sams photofacts, Http://service manuals.net, and go to almost any manuafacturer and type in the maunfactuer and downloads, ie panasonic downloads, toshiba downloads mect ect. its all for you online.. Some are free and some you will have to pay for. Good Luck with youe collecting..
Ps please dont forget to rate this thread.
Philips tv Model - 21PT3525/V7 I want EHT Number ?
The EHT number for a Philips TV model 21PT3525/V7 can vary depending on the specific version of the TV. However, the EHT number for this model is typically BSC25-0235 or BSC25-0217.
It's important to note that replacing the EHT can be a dangerous process, as it involves working with high voltage components. If you're not experienced with electronics repair, it's recommended to seek assistance from a qualified technician who can perform the repair safely and properly.
3/4/2023 1:03:43 AM •
Philips...
Answered
on Mar 04, 2023
How do I program my Magnavox universal remote to my Philips Magnavox fw530c mini Hi-Fi stereo
To program your Magnavox universal remote to your Philips Magnavox FW530C mini Hi-Fi stereo, follow these steps:
- Turn on your Philips Magnavox FW530C mini Hi-Fi stereo manually.
- Press and hold the "Code Search" button on your Magnavox remote until the indicator light turns on.
- Press the "Device" button on the remote, which should be the button corresponding to your stereo.
- Enter the 3-digit code for your stereo. You can find a list of codes for Philips Magnavox products in the user manual for your universal remote or online. If you do not have the manual or cannot find the code online, try entering codes 006, 007, 010, 011, 013, 016, 027, 033, 035, 043, 066, 087, 089, 114, 117, 118, 119, 120, or 123.
- Press the "Power" button on the remote to see if the stereo turns off. If it does, you have successfully programmed the remote. If it does not, repeat steps 2-4 with a different code until you find one that works.
- Once you have programmed the remote to control your stereo, test out the other buttons to make sure they work as well (such as volume control, track skip, etc.).
Note: If you cannot find a code that works for your stereo, you can also try the "Code Search" function on the remote. This may take some time, but it will automatically search for the correct code until it finds one that works.
2/26/2023 6:54:07 AM •
Philips...
Answered
on Feb 26, 2023
