20 Most Recent Philips 20PT6245 TV Questions & Answers
On and off commands come from the main board, if it won't shut off you need a new board
Philips 20PT6245... • Answered on Feb 01, 2018
you can buy a universal remote or on some tvs you can access the menu by either hitting the volume up and down buttons at the same time or it might be the channel buttons so i would try both.GOOD LUCK!!!!!!!
Philips 20PT6245... • Answered on Dec 24, 2010
moisture on components will eventually damage or corode connections i would place it in a very warm place near heating pipes airing cupboard etc and leave it for a couple of days then try again if youre lucky it will drive out moisture and tv will work.
Philips 20PT6245... • Answered on Jan 20, 2010
I had the same problem. I got a Philips Magnavox Universal Remote that has a closed captioning button [CC]. Here's a link to the same type:
http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=pd_bbs_1?ie=UTF8&s=electronics&qid=1240350929&sr=8-1
Philips 20PT6245... • Answered on Apr 21, 2009
Since the TV is only 2 months pld, it must be covered under Warranty. Just take it to the Service Centre and get it fixed. Froim your description it seems that the Horizontal Oscillator or Output section has a short circuit.
Philips 20PT6245... • Answered on Nov 12, 2008
Your problem is a bad sweep power supply or the horizontal sweep circuit has a short in it such as a bad horizontal output transistor as well as the high voltage flyback transformer. These are not problems that should even be concidered to be repaired or attempted to be repaired by an untrained person in solid state electronics. Please seek out a trained service person to estimate the TV for you as there are no user parts inside this set, and a TV set is not a place to be experimenting around inside of.
Philips 20PT6245... • Answered on Oct 07, 2006
Try 606 or 616 one of those should work.
Philips... • Answered on Mar 06, 2021
It could be because the TV's screen is starting to go bad and that your TV's screen and TV are starting to die on you.
Philips... • Answered on Feb 14, 2021
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty. Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Philips... • Answered on Feb 11, 2021
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Philips... • Answered on Dec 21, 2020
Televison & Video Logo
12 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
turning off closed captioning without
  • Televison & Video
