20 Most Recent Sylvania 6427GFF TV Questions & Answers
0answers
Remove onscreen menu of i button from ge universal remote25008 on sylvania tv 6427gff?
Do a reset to this set, and check. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
9/19/2014 6:01:40 PM • Sylvania 6427GFF... • Answered on Sep 19, 2014
THE DEMO ADVERTISMENT KEEPS COMING ON AT THE BOTTOM OF THE SCREEN..HOW DO I TURN IT OFF???
Call Philips (Sylvania) with the model number--most of these sets it is a combination of two or more front control buttons to turn the auto demo mode off---might also be in the owner manual........
4/25/2012 6:19:02 PM • Sylvania 6427GFF... • Answered on Apr 25, 2012
I have damaged coax cable connector. Cannot
Hi
Thanks for using FixYa. Unplug both sides of the crimp connector and cable, if possible, and place the connector ends of the cables in an open location. Now clip the wires just behind the crimp connectors using standard wire clippers. Make a smooth and straight cut to make installing the new connector easier. Strip the insulation off the top of the wires about 3/4 inch back from where you just clipped them, using a sharp knife. To do this, simply slice a groove all the way around the wire insulation and then slide the insulation off. Twist the open wires on the cables to make them more solid. Then, slide them into the corresponding sides of each piece of a new crimp connector. Pinch the grooved section of the crimp connector parts until they are securely bent and pinched on the open, twisted wiring. Don't be afraid to pinch the connectors hard as coaxial wire is very tough and hard to break, especially when twisted. Plug both ends of the cable back in and reconnect both sides of the crimp connector. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
6/16/2010 7:31:11 PM • Sylvania 6427GFF... • Answered on Jun 16, 2010
I need codes for a sylvania tv...model# 6427gff
There could be many Codes depending on the Remote you are using ? Is that a Universal One or Original One?
Try Codes :-
002
021
022
026
062
063
065
124
0030, 0054, 0096, 0381,
133,136,145,101,102,109,111
If that would not work, revert to me with Make and Model of the Remote.
Let me know,if needed further assistance.
Thanks for using ' Fixya ' and have a nice day!!
4/20/2010 12:56:09 AM • Sylvania 6427GFF... • Answered on Apr 20, 2010
Can i hook my laptop up to my sylvania 6427gff tv?
I don't know the TV but it should have either a vga, s-vga or just normal white, yellow and red plug in sockets. If it has any of these, then yes you can.
3/5/2010 9:03:54 PM • Sylvania 6427GFF... • Answered on Mar 05, 2010
Is it possible to cast/mirror/ etc. from ab android phone to a Sylvania TV manufactured in 2005?
No, because screen casting wasn't invented and it isn't a Smart television. Time for a new one.
3/11/2024 8:53:32 PM • Sylvania... • Answered on Mar 11, 2024
I have an old Sylvania tv and it won't turn on
Here are some troubleshooting tips to try. However, as it is an older set, if these tips fail, the cost of a repair at a shop might exceed the value of the TV. In short, a new TV may be in the works. Cross your fingers. One of these tips may work. Let's troubleshoot the issue and try to get it working: If you are using a remote, check the batteries in it. If you are using several remotes with it, try the alternative remote. Sometimes there is a glitch affecting the remote for a Roku where it won't turn on the TV other than a powered black screen and you have to use the other remote to turn it off and back on and then the Roku screen pops up. I have not sorted out why. Check Power Cord and Connections: First, ensure that the power cord is securely plugged into both the TV and the electrical outlet. If you suspect a faulty power cord, consider trying a different one. Reset the TV: While most Sylvania TVs don't have a dedicated reset button, you can perform a manual reset: Unplug the TV's AC adapter from the electrical socket. Press and hold the Power button on the TV for 20 seconds. Plug the AC adapter back in and turn on the TV. Check Audio/Video Cables: Inspect the audio/video cables connecting your TV to the satellite or cable receiver. Ensure that the color-coded prongs match their respective connecting points. Correct any mismatches (e.g., white cable into a red port) by reorganizing the prongs. Inspect Coaxial Cable: Look for the coaxial cable on the rear side of the receiver, attached to the port labeled as ANT IN. Confirm that the connection is firm; a loose coaxial connection can cause display issues. Tighten the cable by pinching the silver band on the end and rotating it clockwise until secure. Check for Interference: If distortion continues on the TV screen, consider nearby interference. Power-hungry appliances can cause electronic interference, affecting display quality. Visit a Repair Shop: If the above steps don't resolve the issue, you may need professional help. Some technical faults, such as a blown fuse or faulty capacitor, require expertise in dismantling and soldering. If uncomfortable with such tasks, consider visiting a repair shop
2/3/2024 6:17:20 AM • Sylvania... • Answered on Feb 03, 2024
2answers
I have a 37in limited edition Sylvania TV I have tried every code on my Phillips universal remote none work. Is there a specific code.
  1. Auto Code Search:
    • Turn on your Sylvania TV.
    • Press and hold the "Code Search" button on your Philips remote until the indicator light stays on.
    • Press the "TV" button on the remote to set it to control the TV.
    • Press the "Power" button repeatedly until the TV turns off.
    • Press the "OK" or "Enter" button to save the code.
  2. Manual Code Entry:
    • Find the code for your Sylvania TV in the Philips remote control manual. If you don't have the manual, you may be able to find it on the Philips website.
    • Press and hold the "Code Search" button on the remote until the indicator light stays on.
    • Enter the code using the number buttons on the remote.
    • Test if the remote now controls your TV. If not, repeat the process with a different code.
  3. Try Common Codes:
    • Some common Sylvania TV remote codes for Philips remotes are 0810, 1684, 1886, 2183, 1081, 1172, 1196, and 2049. Try entering these codes manually.
1/9/2024 10:32:14 PM • Sylvania... • Answered on Jan 09, 2024
Sylvania tv with vcr/dvd player. vcr tape keep being ejected even when using tape cleanser ejected
The most likely cause is a faulty mode switch.
12/12/2023 10:12:41 PM • Sylvania... • Answered on Dec 12, 2023
2answers
Flashing colors on Sylvania lcd TV
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
11/5/2023 2:26:58 AM • Sylvania... • Answered on Nov 05, 2023
Why no tv picture on my Sylvania #ssc092 ac/dc tv/vcr combo?
it is a very simple TV, is TV connected to cable? Here is link to manual copy and past download and save for future reference. It is very old and has CRT not LCD. https://www.manualslib.com/manual/776815/Sylvania-Sylvania-Ssc092.html#manual
10/20/2023 4:15:16 PM • Sylvania... • Answered on Oct 20, 2023
Sylvania tv screen went black last night when we hit a channel button on remote
More likely you hit the Source / Input button and lost the signal. Press it again until it comes back.
9/13/2023 4:08:17 AM • Sylvania... • Answered on Sep 13, 2023
Codes for a Sylvania 32'tv
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote 4-Digit Sylvania TV Codes for Universal Remote
  • 0002.
  • 0008.
  • 0030.
  • 0054.
  • 0068.
  • 0096.
  • 0171.
  • 0321.
More items... • Jan 1, 2023
RCA Universal Remote Codes For Sylvania TV - GenTwenty
6/22/2023 5:33:00 AM • Sylvania... • Answered on Jun 22, 2023
How can I unlock my PIN# on my sylvania smart tablet, and DVD 10.1.
By typing the correct pin or activating a factory reset.
6/17/2023 8:57:49 PM • Sylvania... • Answered on Jun 17, 2023
Does sylvania LC260SS2 support earc/arc with the hdmi inputs?
The Sylvania LC260SS2 has a eArc option called fun-Link. This only works with other fun-Link compatible devices. See https://www.manualslib.com/manual/325827/Sylvania-Lc260ss2.html?page=14#manual . (Sylvania TVs are made by Funai Electric.) It may not work with non-Funai electronics. I hope this helps. Cindy Wells
4/25/2023 10:32:56 PM • Sylvania... • Answered on Apr 25, 2023
Sylvania 6427GFF TV Logo
Popular Tags
13 questions posted
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
will original remote sylvania tv 6427gff
  • Televison & Video
