20 Most Recent Sylvania 6432TE 32" TV Questions & Answers
This problem is caused by your TV's V-chip setting.
To fix the problem:
Push the "Menu" button (on either the remote or the TV's fromt panel).
Use the "Channel Down" button to go to "V-CHIP SETUP"
Use the "Volume Up" button to select it.
In the V-chip setup screen, the rating that is selected by the user as viewable will allow that rating and only lower ratings to be viewed on that TV. (If TV-G) is selected, then any programs rated higher than TV-G will be blocked.
So, the easistway to get rid of any blocking is to set the rating to TV-MA (mature), and then any and all programs will be viewable on that set. Select "TV-MA" by hitting the "Volume Up" button after you have scrolled down to that rating with the "Channel Down" button.
Then hit "Menu" to exit out of the settings and saave your changes.
Sylvania 6432TE... | Answered on Jan 02, 2018
Try a reset to this set, and check. If it do not help you, check and replace its main system control memory IC. It is faulty. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Sylvania 6432TE... | Answered on Oct 14, 2015
check Ebay for a replacement ORIGINAL remote control
Sylvania 6432TE... | Answered on Jul 04, 2015
If you get a picture on regular TV then the tube is fine. If you get audio on game mode try changing the red or white plug to the yellow plug and see if your picture is there. If so you have a bad yellow cord. If not then the solder connection on the board inside TV is bad. If you also have no audio in game mode then the whole board is bad.
Sylvania 6432TE... | Answered on Apr 25, 2014
No. To select the inputs, you must have a remote control.
Sylvania 6432TE... | Answered on Sep 07, 2013
Out of focus picture is your TVs problem I assumes. Seek tech support. Picture tube base socket may need replacement.
Sylvania 6432TE... | Answered on May 24, 2012
Hello
Three digit universal remote codes for Sylvania TV are:
004/008/009/062/068/069/074/075/076/077/133/161&163
Four digit codes are:
0062/0004/0009/0135/0189/0183/0227/0456/0008/0068/0075/0141&0161
OK.
Sylvania 6432TE... | Answered on Aug 31, 2011
I am sorry, you will need the original remote or a remote that is similar.
You can check out 1800remotes.com and see if they chan help.
Thanks
asnowman
Sylvania 6432TE... | Answered on Mar 10, 2011
To fix the problem:
Sylvania 6432TE... | Answered on Jan 24, 2009
replace the H.O.T horiz. Driver Transistor.
comen problem with this set.
Sylvania 6432TE... | Answered on Jan 13, 2009
The code for the Sylvania 6432te 32" TV with the "Innovage products- Jumbo universal remote" is 189. you push and hold down the code search button, when the light starts to flash, hit tv, then the number "189". Finally, push the power button off on the remote control. if the tv turns off, then it worked. :)
Sylvania 6432TE... | Answered on Nov 06, 2008
called for reset on programming by Cox Cable. Worked...amazing!
Sylvania 6432TE... | Answered on Mar 14, 2008
Try a reset to this TV and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sylvania... | Answered on Oct 13, 2020
Sylvania 6432TE 32" TV Logo
Popular Tags
25 questions posted
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
screen display menu keeps coning screen
  • Televison & Video
