20 Most Recent Dell W3201C 32 in. LCD Television Questions & Answers
If you wish to get some details; check the site linked here. Pull up older posts.
Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Dell W3201C 32... | Answered on Jul 10, 2016
I had the same thing happen, I used external system and the sound worked. You can't get the sound board fixed. I tried. Dell TVs stink. And there customer service are no help.
Dell W3201C 32... | Answered on Nov 15, 2015
Sounds like firmware corrupted. Contact the authorized service center for Dell.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dell W3201C 32... | Answered on Aug 11, 2014
SEEMS YOU MAY BE HAVING A BACKLIGHT PROBLEM WITH THE PICTURE GOING DARK.THE BACKLITES IN A LOT OF TVS ARE MADE INTO THE SCREEN PANEL AND ARE NOT REPLACEABLE BUT COULD BE THE BALLAST SUPPLYING THE POWER FOR THE BACKLITE.MOST LIKELY IT'LL TAKE A SHOP TO CHECK IT OUT FOR YOU BUT YOU MIGHT FIND THE INFO ON HERE OR ANOTHER PLACE TO SHOW YOU WHERE IT IS.
Dell W3201C 32... | Answered on Jun 10, 2014
Computer hooked up? Resolution is "Out of Range".
Dell W3201C 32... | Answered on Feb 02, 2014
sounds like your apple TV is putting out a higher resolution than your TV supports. Is the resolution on your tv 720 rather than the 1080 that the apple tv outputs. If that's the case go into the menu on the apple tv and change the output on the apple tv to 720.
this unit needs to be reset. To perform a master reset, do the following: there needs to be a component connected to the input jack. turn to the av station once on the av hit "619" scroll down and select master reset.
Dell W3201C 32... | Answered on Sep 26, 2013
You can only remove the "lock" function by using a DELL remote control (must be a Dell remote) and go to menu and follow instructions.
Good luck
Dell W3201C 32... | Answered on Jul 26, 2013
We also have a 32" LCD Dell flat screen tv #W3201C that has no sound. It's about 2/12 yrs old. One speaker started having a problem and we disconnected it. That was a couple weeks ago, now there is no sound at all. Dell should not be let off the hook so easily. Obviously there is a problem with the tv and it should be Dell's responsibility to make it right. Does anyone know if a class action suit has been initiated?
Dell W3201C 32... | Answered on May 23, 2013
MY KIDS WERE PLAYING WITH THE BUTTONS ON THE TV NOW WHEN I TRY TOO CHANGF THE CHANNELS OUR VOLUME TV BUTTON LOCK ORTV BUTTONED POPS UP.I DONT HAVE MY REMOTE SO WHAT IS ANOTHER METHOD?
Dell W3201C 32... | Answered on Apr 04, 2013
Please clarify your question. Not sure what you mean, since you already posted the model number, brand, size, and that it's an LCD.
Dell W3201C 32... | Answered on Nov 19, 2012
there is monitor out back side of tv set.you can use dell speakers but there is allso need a amp.
all so try reset in lcd tv.
Dell W3201C 32... | Answered on Aug 23, 2012
Looks like incompatibility.
Dell W3201C 32... | Answered on Jul 31, 2012
Dell W3201C 32 in. LCD Television Logo
148 questions posted
Top Dell Televison & Video Experts
CoppellTVRepair.com
Marvin
Marvin
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Televison & Video
Most Popular Question
unlocking tv button lock
  • Televison & Video
