20 Most Recent Westinghouse LTV-32w3 HD Television Questions & Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Westinghouse... | Answered on Jun 16, 2017
Hi John.
Try unplugging the TV for about 30 minutes to an hour (reset TV) to see if this fixes your issue. If it does not, leave the TV unplugged all night and see if it will operate normally. Hope this helps.
Westinghouse... | Answered on May 22, 2017
If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Westinghouse... | Answered on Mar 21, 2014
hi there the 8 pin ic in question is a Viper22a available from good electronic stores i got mine from
Cricklewood electronics for a couple of quid , also replace the capacitor c72 47uf
hope this helped
my board is DPS-210EP B REV 00
should be same
Westinghouse... | Answered on Mar 03, 2014
check cable connections:
1. cable from wall to tv or to pvr. properly connected?
2. yellow,red and white in correct ports?
3. if HD, use green, blue and red to respective ports.
4. is remote properly sync to tv?
5. if no 3 above, get HDMI cable and connect to pvr.
Westinghouse... | Answered on Aug 13, 2013
It might not be a fault with T'Con board, I assumes. Check the ABL circuit well, before replacing T'Con. In fact, the main digital board to your TV need a through checkup. It is a skilled work. If you are not so sound in electronics, it will be best, either contact a service person, or authorized service center.
Westinghouse... | Answered on May 31, 2013
Televison & Video Logo
67 questions posted
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Televison & Video
Most Popular Question
need new power
  • Televison & Video
