20 Most Recent Sanyo PDP-42H2A 42 in. Plasma Television Questions & Answers
cable bos is a scientific atlanta
Sanyo PDP-42H2A... | Answered on Jan 16, 2014
a thousand or so people have experienced this problem! I am a military spouse and our same tv did the same thing on Super Bowl Sunday 2009! We did everything we know to do: call the company, called the repair man, etc. There apparently isn't a solution to this that wouldn't cost more than the tv is worth. So I got an attorney to start a class action:
If you would like to be compensated for your TV please contact me @
[email protected]
Sanyo PDP-42H2A... | Answered on Dec 30, 2012
Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv power supply board for the replacement.
Sanyo PDP-42H2A... | Answered on Aug 11, 2011
Do you get any display up at all? Menu, OSD? Is the PDP priming (lighting up) The best way of testing this is making the room as dark as you can and seeing if the screen is lit.
If there there is none of this then you either have faulty Scan boards or the PDP panel has blown.
Sanyo PDP-42H2A... | Answered on May 25, 2010
Yep. The power supply in Sanyo Plasmas are generally prone to failures. It could be a failure in the panel not priming, but I doubt it. Turn the lights off in the room, then try to turn it on. If you see the screen faintly flash, the panel is priming, but it is not coming on. If the screen is lit, but is still "black," then it is a control or digital board. If it is totally black with no light at all, then it doesn't entirely rule out the first two, but makes a power supply failure more likely.
They usually have a lot of heat damage to them. If you have tried unplugging it for 15 minutes, then plugging it back in and it still doesn't work, the it is most likely a secondary in the power supply.
I hope this helps you...
Sanyo PDP-42H2A... | Answered on Mar 12, 2009
You need a remote control to adjust menu settings.
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=Sanyo++DP46841+remote+controller&_sacat=0
Sanyo Televison... | Answered on Jul 01, 2020
To change the Region code on your player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVD from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software that allows you to play DVDs from any region. There are several available on the Internet but my favourite is DVD-Region Free from ;-
www.dvdidle.com/dvd-region-free.htm
Sanyo Televison... | Answered on Jun 23, 2020
Without its' original remote control; you can't unlock it. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer of your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a compactable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site https://electrohelponline.blogspot.com/
https://remotesearch.blogspot.com/
https://elektrotricks.blogspot.com/
https://homenol.blogspot.com/
Type in the brand name of your device in the search box, and hit enter to get gathered related posts. See the website either in Webview with a mobile, or by a desktop computer. Mobile view has no search box.
Sanyo Televison... | Answered on Jun 04, 2020
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
You cannot, without the remote control.
Sanyo Televison... | Answered on Jun 01, 2020
Instruction:
http://www.manuals.group/results.php?search=SANYO%20DCW%204800%20UM
Sanyo Televison... | Answered on May 22, 2020
happened with my tv too then found their email and mailed them. was researching on https://nect.co/
Sanyo Televison... | Answered on May 19, 2020
5 Ways to Add Apps to a Smart TV - wikiHow
https://www.wikihow.com/Add-Apps-to-a-Smart-TV
Method 5. On Sony Android Smart TVs. Turn on your TV. Press your remote's HOME button. Scroll down to the "Apps" section. Select Store and tap the remote's touch surface. Browse for apps. Select an app you wish to download and tap your remote. Select INSTALL and tap the remote. Select ACCEPT.
Download and install an app - SANYO Incognito - Sprint Support
https://support.sprint.com/.../Download...install...app-SANYO.../WScenario_542_126...
Download and install an app - Sanyo Incognito. With the handset open, press the OK key with the HOME tab highlighted. Scroll to Shopping and press the OK ...
can i download apps on my new sanyo samba 4k tv? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid=20160302213525AAr1hSX
Mar 2, 2016 - Sanyo Smart Tv. Source(s): ... Only the apps supported by Sanyo can be installed. ... If there is no app store, then you can't add any more apps.
Apps - Sanyo FW50C85T Owner's Manual [Page 48] - ManualsLib
https://www.manualslib.com > ... > LCD TV > FW50C85T > Owner's manual
Sanyo FW50C85T Manual Online: Apps. Apps offers Internet Services for your TV. Use the TV Remote Control to browse the App's pages. You can Play Movies, listen to Music and much more, all from your TV screen. Because ... You cannot Download and Save Files or Install Plug-ins. - ... Led18.5" hdtv lcd (27 pages).
Videos as well
https://www.google.com/search?q=add+apps+to+Sanyo+smart+tv&safe=off&source=lnms&tbm=vid&sa=X&ved=0ahUKEwjRgPm4oMTgAhWVn4MKHa7rD4oQ_AUIDigB&biw=1366&bih=625
Sanyo Televison... | Answered on May 18, 2020
The TV will need a power supply, are there any power lights on to indicate it could be on standby?
Sanyo Televison... | Answered on May 11, 2020
Sanyo PDP-42H2A 42 in. Plasma Television Logo
Popular Tags
13 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
sanyo plasma tv
  • Televison & Video
