20 Most Recent Sony FWD50PX2/S 50 in. Plasma Television Questions & Answers
this is a common issue i think. below steps solved this issue for an user.
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Sony FWD50PX2/S... | Answered on Jun 23, 2017
There is no other way out than to replace the screen. Now the most important part is to get the estimate of the new screen before you can decide if this is feasible then to buy a new TV with the new formats.
So check this out and make sure you insurance covers this next time.
Sony FWD50PX2/S... | Answered on Feb 20, 2011
The tv power supply board have problems.That the board,where the power a/c cord plug into it.try website like Ebay.com to buy a refurbish power supply board for the replacement.
Sony FWD50PX2/S... | Answered on Oct 26, 2010
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you open up the TV, you may find a bad part stick out like a sore thumb.
If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Sony FWD50PX2/S... | Answered on Apr 16, 2010
bad panel or video board.
Sony FWD50PX2/S... | Answered on Apr 09, 2010
The monitor should have come with several cables and adapters. One adapter converts the stereo RCA plugs to a stereo 1/4 inch plug that connects next to the dvi outlet.
Sony FWD50PX2/S... | Answered on Dec 23, 2009
Well its possibly more than just the power supply. The click you hear is the relay trying to start the TV. If it detectcs a voltage diffent to what it expects it stops and ties again. If the diffence is still detected it shuts down any display or sound function. there are many TV's on here that all have the same symptoms and faults.
There are 3 boards inside power Sustain 1 and Sustain 2. your problem is likely to be on the second board, but not necessaily the primary fault. The fault may be emmanating from any of or both the other boards.
There are a number of capacitors and even the convergence chip and also in some cases the power chip on the power board and both boards affected. You cannot play board swap jockey and fix it as it requires technical intervention with the right tools, test equipment, circuit diagram and the ability to generate a hatch pattern on the screen to tune the convergence . It is recommended all 3 boards are changed simultaneously to prevent the domino effect. This is NOT a DIY
Many try and rarely succeed and end up spending more $$ than a one off visit to a professinal and a fix. Cost of parts for this is abouy $300 + 1.5-2 hrs of labour.
If this unit is under warranty or extended warranty call it in now. refrain from trying to start it in case it catches fire. Some less skilled will possibly tell you to unp-lug it for 8 hrs replug it and it will start...maybe but it is still in a faulty and fire risk state and may only last a short time before combusting.
Thanks for using FIXYA
Sony FWD50PX2/S... | Answered on Dec 01, 2009
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher. You should call the manufacturer for your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Sony FWD50PX2/S... | Answered on Aug 05, 2009
Tv's usually do not have VIDEO outputs, some have audio outputs so you can connect to a reciever.
Do you need help with a connection? Let us know what you are trying to do and I will be happy to help.. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Sony FWD50PX2/S... | Answered on Jan 21, 2009
In most cases on a plama TV the upper and lower buffer boards will cause diagonal lines to appear in the picture in top or bottom half or sometimes both.
Sony FWD50PX2/S... | Answered on Jan 16, 2009
Hello Zirben:
You will ned to have your Tv looked at by a repair shop there seems to be a problem with the small singal board.
The Slash
Sony FWD50PX2/S... | Answered on Aug 22, 2008
Hello Sherry:
you will need to hav th unit repaired it ounds like there is a problem with your small signal board.
The Slash
Sony FWD50PX2/S... | Answered on Aug 17, 2008
Sony FWD50PX2/S 50 in. Plasma Television Logo
39 questions posted
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony fwd50px2 screen displays color
  • Televison & Video
