20 Most Recent Sony BRAVIA KDL-26S2000 26 in. LCD HDTV Questions & Answers
Turn off teletext 888
Click here to download the user manual to this set, and refer it.
6/10/2012 2:02:05 AM • Sony BRAVIA... • Answered on Jun 10, 2012
Apple tv and Sony Bravia 26S2030
HDMI contains both video, color and audio all in one cable----audio connection with it is not without issues.
5/15/2012 6:54:35 AM • Sony BRAVIA... • Answered on May 15, 2012
Which button on the remote control is for switching from TV to AV (VCR)?
The TV/Video button on the original remote for the KDL-26S2000 should let you cycle through the inputs on the TV. This button is at the upper left of the remote. (However, if you have set the system to Skip inputs, you may need to remove the skip option.) There is also a TV/Video button on the front of the TV. It's the second button from the left on the panel (it's just to the right of the menu button). To reset the input list, press Menu and navigate to Settings. Select the Setup sub-menu and then select the Label Video Inputs. Give the input any label other than skip. Some TVs work best if the TV is turned on and set to that input source before you turn on the source device. For additional information and pictures of the menus, see the manual. It is available from Sony support: http://esupport.sony.com/US/perl/model-home.pl?mdl=KDL26S2000&template_id=1&region_id=1&tab=manuals#/manualsTab (see the Manuals, Specs and Warranty tab). The direct link to the manual is http://www.docs.sony.com/release/KDL40S2000.pdf .I hope this helps. Cindy Wells
1/1/2012 1:35:58 AM • Sony BRAVIA... • Answered on Jan 01, 2012
My Sony Bravia lost its picture
Please check the connections on the back and hope that you find a loose video connector. If that doesn't fix it then continue onto the source to see if that might have a loose connector.
The next thing to check would be the other inputs using the TV/Video button to see if the video on all of the inputs is dead. That would be what might be called "bad news".
2/26/2009 1:58:26 AM • Sony BRAVIA... • Answered on Feb 26, 2009
Tuning problem
The tuner is bad. Could also be the video process, since the hi-def is decoded there
11/12/2008 8:36:17 PM • Sony BRAVIA... • Answered on Nov 12, 2008
Samsung dvr/vcr
A scart lead should do the trick.
4/20/2008 4:51:36 PM • Sony BRAVIA... • Answered on Apr 20, 2008
Sony Bravia KDL-50R550A keeps turning on and off after 15 seconds? Changed batteries & unplugged 60 seconds. Should I reset?
You can try but I don't think that will help, sounds like power supply issues, open the back and look for bulged caps
10/11/2021 12:09:29 AM • Sony BRAVIA... • Answered on Oct 11, 2021
No sound some channels
HI IN THIS CASE YOU LED TV CHANG AUDIO FORMATE PLEASE GO TO TUNING SECTION THEN IN FINE TUNING AND THERE IS SOUND OPTIOND LIKE BG DK I AND M SELECT ONE ACCORDING TO YOUR COUNTRY THANKS M NASIR
10/3/2021 4:54:49 PM • Sony BRAVIA... • Answered on Oct 03, 2021
Hi, I've Sony Brevia LCD tv model # kdl 32bx300. Its displaying green discolored pictures. Is it T Con board problem or main board issue?
Hi dear its main board problem and some time LVDS FFC cable problem . thanks M Nasir
10/1/2021 6:19:26 PM • Sony BRAVIA... • Answered on Oct 01, 2021
Sony 65 inch TV, KD-65X750F not getting any power from stand-by pin on power board?
Do you get voltage with the main board unhooked?
8/3/2021 10:50:25 AM • Sony BRAVIA... • Answered on Aug 03, 2021
I have a sony bravia 55" TV, the model # is kdl 65w850c with a part that came loose. According to the Service Manual I downloaded, it's called a BT antenna.
THe antenna came of. Did you use it and is it giving troubles now? If not, then don't mind and leave it.
7/17/2021 3:24:06 PM • Sony BRAVIA... • Answered on Jul 17, 2021
Sony BRAVIA KDL-26S2000 26 in. LCD HDTV Logo
23 questions posted
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
turn off teletext 888
  • Televison & Video
