20 Most Recent
Memorex MLT1522 15 in. LCD Television Questions & Answers
Lost remote for mlt1522 lcd
Try a ONE FOR ALL universal remote. They should work with Memorex tvs.
Try the follwing codes: 0056, 0150, 0154, 0016, 0178
Good luck and please post back on how you make out.
Have a memorex 15"lcd tv brand new and cannot find code
Hi RenoaGin,
You would agree that these companies are more smart than us. They know if they keep the same codes, it would hit them. They might be out of the business :)
Rarest of rare you would be able to find a correct remote code. However not bad to give a shot,. You never know when you hit the target.
I have few codes for you....
018
032
090
Thanks for using Fixya.
Do rate the solution.
My memorex hdmi mirror for android isn't putting out wifi signal
It seems like the Wi-Fi module on your Memorex HDMI Mirror may be faulty or malfunctioning, preventing it from broadcasting a Wi-Fi signal. Here are a few troubleshooting steps you can try:
Make sure your Memorex HDMI Mirror is within range of your Wi-Fi router. Move it closer to see if it picks up the signal.
Reset the Wi-Fi module by pressing and holding the reset button on the device for at least 10 seconds. Make sure the device is not connected to the TV while doing this.
Try connecting the Memorex HDMI Mirror to a different HDMI port on your TV to see if that resolves the issue.
Check if there are any firmware updates available for the device. If there are, update the firmware and try again.
If none of the above steps work, you may need to contact Memorex customer support or take the device to a repair shop to have it checked for any hardware issues.
2/24/2023 2:32:24 PM •
Memorex...
Answered
on Feb 24, 2023
How do I power on my Memorex HDMI screen mirroring device
- Make sure the device is properly plugged into a functioning HDMI port on your TV.
- Check the power cord for the device to make sure it is properly plugged into a functioning outlet.
- Check the TV's settings to ensure that the correct HDMI input is selected.
- Press the power button on the device to turn it on. If the device has a separate power switch, make sure it is in the "On" position.
1/3/2023 11:31:16 PM •
Memorex...
Answered
on Jan 03, 2023
My memorex hdmi mirror for android isn't working
Once memorex is connected to your tv and you've provided the correct username and password for your hotspot, then everything should work at least at some pace.
Please keep in mind that any type of streaming over mobile data maybe limited based on your mobile plan.
Whereas if you use, home or office based wifi, the streaming should be more fluid.
If still having an issue, please unplug and then plug back your memorex device before trying to connect to wifi again.
Thank you.
10/15/2022 9:37:43 PM •
Memorex...
Answered
on Oct 15, 2022
