20 Most Recent Belkin (F5D7050) 802.11a/g/b Wireless Adapter Questions & Answers
Belkin wireless G+ usb adapter
AOL has been and will always have problem (had to do repairs on AOL computers since 1994)
If you have a DSL or Cable connection why pay again for AOL? That means you are paying twice for the same internet connection - and AOL causes lots of problems.
For AOL problems, it is best to contact AOL.
1/29/2020 7:22:16 PM • Belkin (F5D7050)... • Answered on Jan 29, 2020
Find my wep key
Oh, sorry I didn't see it in the title before. First, check the dirvers are properly installed for the adapter. Then if you don't have the wep key, connect by cable or other computer connected to your router (better by cable, as you can have restricted access to router setup menu from wi-fi). The WEP will be in WIFI config. section. If you cant log in to your router, try export the config profile out from another wifi connected PC and import it into new device wifi config software (if they support the same profiles). If nothing of this helped, you can still reset the router (find in manual- most often disconnect from power and push reset button for about 10 seconds) and setup WIFI with new WEP key. Don't forget to write the wep down. If WEP is not your problem but connectivity of the adapter to internet or network at all, describe the problem more deeply
10/14/2018 4:39:35 PM • Belkin (F5D7050)... • Answered on Oct 14, 2018
Yeah hey...belkin wireless router password reset
What is the brand of the router your using? This information will be from the router that you have. Use a wired connection from the router,check your default gateway (ipconfig) and type that numbers in your address bar. You will be able to access your set-up page, look for wireless tab and look for wireless security. You will see there your WEP key.
11/30/2017 12:58:34 PM • Belkin (F5D7050)... • Answered on Nov 30, 2017
0answers
My internet keeps disconnecting
It sounds like the wire from your house to the isp switch is faulty you should probably call them down to fix. Or it could just be the modem are you using the same modem for both computers? If so then that's probably the problem.
6/8/2015 2:52:01 PM • Belkin (F5D7050)... • Answered on Jun 08, 2015
Safari won't access web page with my iPad air
There are problems with the Belkin site. It may even be that someone has sabotaged it. I had problems using the Belkin drivers and discovered that two of the files (I needed version 2 files for my F5D7050 Wireless Adapter) were actually version 1 files and I found the correct files (all the same names, but different sizes) on the Drivers Guide site (do not download their download helper file - it messes up your computer and takes a lot of work to get rid of it). Also, searching for the drivers is made more difficult because one of them is actually misspelled on the Belkin site. Sorry I did not keep notes about which one I found was wrong.
8/16/2014 12:27:32 PM • Belkin (F5D7050)... • Answered on Aug 16, 2014
Using belkin f5d7051 and getting wlancfgg.exe error message
There are problems with the Belkin site. It may even be that someone has sabotaged it. I had problems using the Belkin drivers and discovered that two of the files (I needed version 2 files for my Wireless Adapter) were actually version 1 files and I found the correct files (all the same names, but different sizes) on the Drivers Guide site (do not download their download helper file - it messes up your computer and takes a lot of work to get rid of it). Also, searching for the drivers is made more difficult because one of them is actually misspelled on the Belkin site. Sorry I did not keep notes about which one I found.
8/16/2014 12:03:51 PM • Belkin (F5D7050)... • Answered on Aug 16, 2014
2answers
Connects to home hub but not internet?
belkin adapter has a signal says its on but wont connect to the internet helpppp
4/15/2014 3:49:24 PM • Belkin (F5D7050)... • Answered on Apr 15, 2014
Please insert disk 1 with layout.bin
Choose your OS correctly at BELKIN
7/4/2013 6:29:23 AM • Belkin (F5D7050)... • Answered on Jul 04, 2013
Ethernet controller error in device manager tp-link wn353g
  1. Open Device Manager by clicking the Start button , clicking Control Panel, clicking System and Maintenance, and then clicking DM If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. In Device Manager, locate the device under Network adapters, and then double-click the device name.
  3. Click the Driver tab, and then click Update Driver.
  4. In the Update Driver Software wizard, click Browse my computer for driver software.
  5. Click the Browse button and go to the location on your computer where you saved the new driver files.
  6. Click OK, and then click Next to install the driver.
2/1/2013 1:40:06 AM • Belkin (F5D7050)... • Answered on Feb 01, 2013
My laptop will not connect to the internet without
HIdid you installed the drivers with the disk in the box ?did you tried to install the device on another computer ? bernardhttp://www.rylwy.com/
8/6/2012 9:50:47 AM • Belkin (F5D7050)... • Answered on Aug 06, 2012
2answers
Usb adapter do not work with my new
CLICK HERE to download the Windows 7 Drivers
You will have to find and download the correct version (Guidelines to find the version will be given in the same page )
8/3/2012 4:24:30 PM • Belkin (F5D7050)... • Answered on Aug 03, 2012
I have lost my disc to install belkin where can i get one from
you can usually go to their website and access drivers there....
2/29/2012 2:44:08 PM • Belkin (F5D7050)... • Answered on Feb 29, 2012
Http://en-us-support.belkin.com/app/answers/detail/a_id/297/~/f5d7050-wireless-g-usb-network-adapter---drivers i got the version
Well, I would recommend you to install the version 2 of the driver that can be downloaded from the below link:
http://cache-www.belkin.com/support/dl/f5d7050v2.exe
I believe this would help resolve the issue.
Regards
Anand
5/6/2011 12:46:38 AM • Belkin (F5D7050)... • Answered on May 06, 2011
Belkin usb adapter and windows me no good? what
Have you installed drivers for it? If not, immediately install them. If it still doesn't work then maybe it is malfunctioning.
5/5/2011 12:27:55 AM • Belkin (F5D7050)... • Answered on May 05, 2011
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
197 questions posted
Top Belkin Computers & Internet Experts
Donivan Wise
Mehandi Husain ...
Mike
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
usb adapter not work new
  • Computers & Internet
