20 Most Recent GPX PDL705 Questions & Answers
Did you use the right format when burning? This dvd player will not play all formats.
GPX PDL705 | Answered on Apr 29, 2014
Did you find n answer?
GPX PDL705 | Answered on Jan 15, 2012
Turn on power. Open lid. Enter 9735 with the remote and press 'enter', you can choose between making your player region-free or a different region in addition to R1. Select the desired region unlock and press 'enter'.
GPX PDL705 | Answered on Apr 28, 2011
change the settings from pal ntsc or secam, depending on what system you are using. I.e. if it is in pal then change it to ntsc and vise versa
GPX PDL705 | Answered on Mar 10, 2011
Hello:
This problem happens alot, electric shock carried in the body can and will cause units to fail. Especially if new carpet is installed. Altho it may seem small in human stardards but most electronics built today use CMOS chips which are highly sensitive to electronic static shock, That small about of electricity carried in your body after walking on some surfaces such as carpet can be thousands of volts, example when you walk across a room and touch a door handle. This voltage carried in you if not properly grounded will enter the electronics device and destroy sensitive cmos IC's. I suggest you open the unit and look for possible bad fuse in not the replace the unit there is nothing you can do other then replacing the board.
GPX PDL705 | Answered on Aug 15, 2010
GPX PDL705 | Answered on Dec 06, 2009
Probably the laser lens needs cleaning.
Purchase a laser lens cleaner disc at Radio Shack ($13). No chemicals are involved.
Read & follow the instructions. It cannot harm the player if not done right.
GPX PDL705 | Answered on Sep 30, 2009
I heve worked with so many DVD players including playstation2 a while back. Almost all the time this problem is caused by a bad laser diode assembly. You can order one for your particular model, but they are not easy to replace, even for an electronic guy like me. A mechanical talent is a must.
GPX PDL705 | Answered on Jun 29, 2009
I needed to enter a password to use without parental control. Works fine now.
Thanks
GPX PDL705 | Answered on Jun 14, 2009
I have uploaded the GPX PDL705 manual to this site today. If you check tomorrow they may have posted it by then.
If you look at the small print on the adaptor it should indicate by diagram Voltage output, current capacity, type and tip polarity by small diagram. Most adaptors are 'positive' -- but if you are unsure do not plug the adaptor into the device because it will fry it!
GPX PDL705 | Answered on May 31, 2009
I just called Gpx for a Car charger and they had in stock (as of 6-17-08) it was $14.99.... the wall carger was $9.99. Hope that helps. GPX phone # 314-621-2881.
it is positive
You can buy a new one by clicking on the hyperlink:
buy replacement ac power adapter charger GPX PDL705
I check the motor. for sping its good. clean the liner eye it's good also check for bad hardness connection it,s with um meter. ok what can it be
GPX PDL705 | Answered on May 21, 2009
I hope this helps^^ try it and gimme a shout!
Turn on power.
Open lid.
Push 9 7 3 5 from the remote.
Select 0 using arrow keys.
Exit Setup.
Done.
The one above did work me, only that after one turns on the player, enter in the 9735 with the remote and press 'enter', you can choose between making your player region-free or a different region in addition to R1. Select the desired region unlock and press 'enter'.
Make sure you check the bottom of the DVD player to see if it was manufactured in the first quarter of 2007, that might factor in whether the code can work or not.
GPX PDL705 | Answered on Apr 01, 2009
Try cleaning the lens. I usually get the same problem with my disks, but cleaning the lens makes it work again. Or check which format is compatible with your player. It will also say no disc if it is not. hope i was able to help^^ goodluck
GPX PDL705 | Answered on Mar 30, 2009
GPX PDL705 Logo
Popular Tags
33 questions posted
Top GPX Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Steven Wander
Steven Wander
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • GPX Televison & Video
Most Popular Question
gpx d2800 will not play dvdrw r disks
  • Televison & Video
