20 Most Recent
Raymarine ST4000 GPS Receiver Questions & Answers
My st4000 wheel pilot turns on with the boat,
Are you sure that you've got the correct value fuse in? Check that the motor/gearbox assembly will turn; ie, it's not siezed up. Check the wiring to the motor to make sure that there's no short circuit anywhere.
Radar Raymarine HD wiring diagram, how to wire to Raymarine C120 unit
After nearly 4 years I dunno if you got this sorted.
The question is ambiguous, as Raymarine radar comes with wiring harnesses; the display end is a plug-and-play 12-pin male to the harness end female; the other end goes up the mast in a plastic sleeve to prevent damage to the 8-pin connector and the 2 or 4 power cables (depends on "light" or "heavy").
There's a means of connecting a digital radar to the C120 but I don't have that so don't know the specifics.
Is this the sort of information you were looking for?
