20 Most Recent KitchenAid KHVU781RSS Stainless Steel Kitchen Hood Questions & Answers
Bring a focal point to your kitchen by having an island range hood, combining function and elegant form. A suspended hood is also an efficient way to vent
grease, odors and smoke to the outside from a island stovetop while you cook. You can install an island range hood in just a few hours with the right tools
and knowledge.
1.Wear safety glasses and work gloves. Turn off the electricity to your kitchen at the circuit panel. Cover the circuit breaker with a piece of electrical
tape to prevent people from turning the on switch while you are at work.
2.Lay work drop cloths on your cooktop and floor to catch dust and debris. Mark the duct opening with a pencil in the ceiling, where the island hood will be
installed. Be sure the opening is centered directly above your cooktop. Cut the opening using a hacksaw.
3.Go up to the roof, using a cat's claw and hammer to remove stucco, tiles, sheathing and insulation to make way for the steel venting duct. Drop a
plumb bob down the roof, making sure the line is straight down for the ductwork.
4.Follow the manufacturer's instructions for locations, installing 2-by-2 wooden blocks in the ceiling to hold the ductwork hangers.
5.Install the venting duct from the outside of the home, down to the location of the exhaust vents on the island hood. The ducts should easily slip into each
other. Secure all the duct sections with duct sealing putty, using a putty knife.
6.Screw a roof cap on the end of the duct at the roof. Seal any openings or gaps where the roof, ceiling and duct meet with silicon sealant. Let the sealant
dry, then paint with colors matched to the surrounds.
7.Place your hood upside-down on the floor, with the fan and filter facing upward. Locate and unscrew the metal electrical box cover on the island range
hood, to expose the wiring
8.Install the hood cover to the load-bearing ceiling frame with the package hardware through the four inside mounting corner flanges on the cover.
9.Measure what will be the distance from the bottom of your hood to the cooktop; it should not exceed 30 inches for exhaust efficiency. Have a helper hold
the hood in place while you attach the hood on the hood cover using the included screws. Use a level be sure the hood is level as mounted.
10.Connect the electrical wiring by consulting the manufacturer's suggestions or hire an electrician if you are not familiar with house wiring. Tuck the wires neatly in the hood electrical box and then replace the cover, after connecting the hood wires to the wall wiring.
11.Remove the electrical tape on the circuit breaker, turn on the electricity to your kitchen and test your island range hood.
KitchenAid... | Answered on Aug 09, 2012
I didn't see an operator manual using https://www.google.com
There were several diagrams and parts lists.
An installation manual and a toll free number to call for support is at the link below:
https://www.partselect.com/Models/KESH307HBS4/
KitchenAid... | Answered on Oct 04, 2019
Have you unplugged the appliance I reset it see if that clears it
KitchenAid... | Answered on Sep 15, 2019
Same here. I am in trouble like that. Need to find a solution!
Best,
http://giaydankinhgiahuy.com/
KitchenAid... | Answered on Sep 07, 2019
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Aug 07, 2019 | Kitchen Ranges
Good Morning, An E1-f2 E1F2 error indicates a faulty touchpad. Fixyourboard.com offers replacement Ledgestone Technologies touchpads for Kitchenaid oven models. Reach out to them for more information 512-355-1108 or [email protected]
KitchenAid... | Answered on Jun 19, 2019
Odds are that element is bad and needs replaced some minor testing needs to be done to know for sure. I have attached a picture of the elements as they are different depending on position. #12 is the part. Sears parts direct can get you the part numbers.
KitchenAid... | Answered on Feb 09, 2019
Have you tried running the exhaust fan when using the stove? Also you might try using the back burners. It sounds like the microwave is sitting too low and this may cause more issues as the time goes on.
KitchenAid KHVU781RSS Stainless Steel Kitchen Hood Logo
Popular Tags
1 questions posted
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Kitchen Ranges
Most Popular Question
installed over island
  • Kitchen Ranges
