20 Most Recent
Garmin GPSMAP 60CSx Questions & Answers
American English voices "Jack" and "Jill" are missing from my Garmin 2597
This is very easy to resolve. Connect the unit to your PC with a USB cable and go to the Garmin website and download Garmin Express or Garmin Web Updater. These programs will scan your unit and offer you additional files to download. If you still have trouble, email me at sharcnet-usa AT sharc DOT net and I can send you the files.
How to delete maps from
put SD card in computer, it will now be detected and open a box
you can open that box and delete there.... or go on computer to your files and go to that Drive and look in there and find Garmin files on the SC card
Electrical burn Garmin Rino
I would suggest sending it to Garmin for an estimate of repair. We have no way of knowing the damage that has been done.
How to delete all waypoints
Create a new file in Mapsource, with one anonymous waypoint, and one map tile and send to unit. It will then replace what is existing on the unit at present. Otherwise, you'll have to delete the waypoints one by one, but there is no way of deleting the maps (unless they are stored on the Micro SD chip - in that case, just reformat the chip).
On my Garmin GPS maps 60 csx there are no
This happens to about 1% of the units I've sold. Sometimes the GPS antenna software reverts to version 0.00 which of course is nothing. Check in the GPS by going: Menu > Menu > Setup > System > Menu to see the versions installed.
Use Garmin WebUpdater (free from Garmin web site) to reload the software and update if necessary - they bring out updates a few times a year - it's all free and very easy to do using WebUpdater.
Garmin 60CSx - Cant find satellites
Try a re-load of the chipset driver. It is available from the Garmin website. I find that it occasionally becomes corrupt.
You can check by entering the "Main Menu" then "Setup" then "System" then press Menu and choose "Software Version".
If the "GPS SW Version" is 0.00 then a reload of the chipset driver will correct the problem.
Cheers.
Need satellite
Go to garmins site and download the fix for this issue. Have fixed several of these. They have the download there. I just fixed one the other day.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Garmin MAP 60CSx
try calibrating the compass. make sure the battery type is set to the correct type.
Garmin Nuvi 650
1. Browse here and install the latest version of WebUpdater:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
2.
Turn on your Nuvi, press view map, press speed, press and hold the
middle of the speedometer (the circle that says 0.0mph in it). After
five seconds (maybe a bit longer), the engineering menu will appear.
3. Press "Next" five times (once for each page). You will arrive at the "Bluetooth Status" page.
4. Press "Clear". Confirm by pressing "yes".
5. Press "Updt PR". Confirm by pressing "yes".
6. This probably did _nothing_ for you, but to be thorough, I've included the steps.
7.
Connect the Nuvi to your computer. Run the webupdater and if the latest
version is already detected on your Nuvi, simply proceed and browse the
list of further updates.
8. If "Bluetooth Firmware Update..."
(or similar text) DOES NOT APPEAR skip to step 10 below, otherwise
complete your fix with the next step, step 9.
9. If the
"Bluetooth Firmware Update..." (or similar text) appears in your list,
select this update and agree to term of service, and have the updater
load the firmware onto your device. Unplug your device. It should
powerup automatically. Power off. Power back on. Your BT should be back
in business. Do NOT continue with the next steps. You are done.
10.
If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR in
the list, then you need to remove the offending update that is making
WebUpdater believe that your Nuvi is up-to-date.
11. You can access the Nuvi by clicking on "My Computer" and double clicking the Nuvi link.
12. Click the "Garmin" folder.
13. Click the "RemoteSW" folder.
14.
DELETE "006B055301.GCD". This file will be one of two GCD files in the
directory: <DRIVE>:\Garmin\RemoteSW. The file without the "Date
Modified" is the original firmware. The other file is the new firmware
that the Nuvi believes is installed. By deleting the newer of the two
files, WebUpdater will see that your Nuvi is out-of-date. Return to
step 8 to continue your fix.
This should resolve all permutations of this nasty bug.
