20 Most Recent KitchenAid KSS48QM 48" Built-In Side-By-Side Refrigerator w/ 29.8 Cu. Ft. Capacity, In-Door-Ice Disp... Questions & Answers
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
KitchenAid... | Answered on Oct 14, 2009
Vacuum all the condenser fins of fluff and dust. Disconnect from the mains supply for 10 minutes.
Google
make model manual
and look in the troubleshooting section.
This may help you, replace a capacitor.
https://www.applianceblog.com/mainforums/threads/kbls36fkx02-kitchenaid-built-in-working-fine-but-beeping-over-and-over.48650/
Call for Service - Built In Refrigerator - Product Help ' KitchenAid
producthelp.kitchenaid.com > Built_In_Refrigerator > Other
Dec 14, 2019 - If the "Call for Service" light is blinking or flashing, try resetting the power to the unit: Power unit down by turning off the circuit breaker(s) for five (5) minutes. Power unit up by turning on the circuit breaker(s). Monitor the refrigerator for a couple of minutes to ensure the error code does not display again.
Service & Support ' KitchenAid
www.kitchenaid.ca > en_ca > service-and-support
Virtually hold your place in line or schedule a call back. Note: Scheduled callback is also available outside of operating hours. Check out more resources below.
FIXED - KBLS36FKX02 KitchenAid Built-In working fine but ...
www.applianceblog.com > ... > KitchenAid
Jan 7, 2015 - We have a KitchenAid built-in KBLS36FKX02 that started beeping every few ... I called KitchenAid to see if I could schedule an authorized repair ... So... the fridge is working fine -- the only issue is the constant beeping. Is there ...
KitchenAid... | Answered on Dec 20, 2020
Contact the seller for an explanation
KitchenAid... | Answered on Nov 20, 2020
The ice maker needs to be replaced and it not working anymore.
KitchenAid... | Answered on Aug 22, 2020
May be able to contact this site below to ask for assistance. List of typical symptoms shown there.
https://www.partselect.com/Models/KSRP25FNSS00/#Symptoms
KitchenAid... | Answered on Jun 04, 2020
The blower is poor or somethin restrictd from the evaporator in the freezer area. Also u may need the compressor..or condensor testd. On an old fridge its cheaper to just buy a good used..cause parts n labor
KitchenAid... | Answered on May 22, 2020
https://www.youtube.com/watch?v=V1wDeBxT4A8
KitchenAid... | Answered on Apr 24, 2020
A common reason a condenser fan is continually running within a refrigerator is the thermostat. ... A basic test is to set the thermostat on the warmest setting; if the cooling unit continues to run, even when it's being told to keep the fridge warmer, you have a broken thermostat.
https://homeguides.sfgate.com/refrigerator-condenser-fan-always-running-37696.html
KitchenAid... | Answered on Apr 22, 2020
Kitchenaid has a dimensions guide for the KSC25FKSS refrigerators on their support site: https://www.kitchenaid.com/service-and-support/manuals.html . The depth depends on the handle style; these models are 35 1/2" W X 27" or 27 1/2" D X 71 7/8" H. The link to the document is https://www.kitchenaid.com/content/dam/global/documents/200312/dimension-guide-2221514-D-KA.pdf .
I hope this helps.
KitchenAid... | Answered on Nov 29, 2019
With an ice build up this much, the auto defrost wont have any chance of working so you will have to do a manual defrost.
Just turn off the power and wait a few hours for the thing to fully defrost. You can help things along by using a hair dryer, but avoid sharp objects and scrapers as you may damage something.
You will have to store the things from the refrigerator in someone else's fridge or in foam boxes while you do this to avoid damage to the food.
When you open the fridge door in the future to get things in or out, try to not leave it open for more than a few seconds at a time as this will help avoid it doing this again. Each time you open the door, you let moist warm air go inside and this contributes to the ice build up.
KitchenAid... | Answered on Sep 15, 2019
Yep it's for fruit. Can tannin and out to empty and clean
KitchenAid... | Answered on May 04, 2019
Take the lower panel off the bottom of the refrigerator in back. Turn your refrigerator on and make sure the fan on the condenser coil is turning and check to see how dirty the coil is. If it's going out on over temp, it means you can't expel heat.
KitchenAid... | Answered on Apr 08, 2019
Refrigerators Logo
1 questions posted
Top KitchenAid Refrigerators Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Refrigerators
Most Popular Question
kitchen aid top shelf warm
  • Refrigerators
