20 Most Recent
Acer Ferrari 4000 Laptop Notebook Questions & Answers
Alt + F10 combination doesn't work
and it will if win xp is the only operating system installed
the defaults come after the os is up and running and all of the default settings can be changed in the control panel defaults
How do i power up my acer ferrari 4000
Remove main battery and try again, if nothing! check power adapter for correct voltage, If okay! sub out the ram memory one at a time and test, still no change! the DC jack is often the source of trouble and the laptop will need to be dismantled down to the motherboard level, the DC jack will probably need resoldering.
Acer Ferrarri laptop - set a bios password and
i not sure but ill try to help all bios password user
enter wrong password 3 time if u get a code send me that code ill send u master password if i could not help dont angry let me know ill find another way.. Thanks
It runs ok, but over
It needs a service, in that it is overheating and therefore shuts itself down to prevent permanent damage to itself.
It will be professionally cleaned of all dust by a computer technician, he/she will test the cooling equipment to ensure that it is doing it's job effectively. When in use ensure that it is raised off the table to ensure sufficient air can pass through the laptop computer.
damnor01
Ferrari 4000 laptop a/c adaptor will not charge laptop,adaptor ok
Hi
Thank you for your query it sounds like you have multiple hardware issues
1) you mention that the ac adapter does not charge, then you say ac adapter ok. Please clarify if the adapter is faulty or the battery
2) As for the line in your screen, your LCD is faulty and will need to be replaced
I would recommend that you book the laptop into a reputable PC shop for further investigation/repair
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
