20 Most Recent Dual 15" Bandpass Sub Box Enclosure Plexi 3/4" MDF Car Speaker Questions & Answers
Check the specs on your speakers and the amount of cubic space it needs to breathe and amount of porting required and then check the box to see if it meets that requirement otherwise if it doesn't it will sound like **** and be highly distorted.
Dual 15"... | Answered on Dec 10, 2010
I have a 2004 dodge ram and once I hook up yellow wire it blows a fuse any help would be nice
Dual Car Audio &... | Answered on Nov 15, 2019
I wouldn't, you need an amp that can support a 1.1 ohm load. I don't know of any head unit onboard amp that can!
Dual Car Audio &... | Answered on Oct 20, 2019
Hi Chris, from what you said, it would seem like a loose antenna connection problem
Review and comment
Greetings Franco Dosil
Hola Chris, por lo que comentas, parecer?a un problema de conexi?n de antena flojo
Revisa y comenta
Saludos Franco Dosil
http://www.ps2netdrivers.net/manual/dual.xdm6820/
Dual Car Audio &... | Answered on Oct 12, 2019
Hi Robert, whenever you put two or more speakers in parallel, the power handling must be equal in each speaker and the sum total of the power of the speakers, must be greater than the power of the amplifier, to avoid breakages due to excesses of power
I hope my comment has served you
Hola Robert, siempre que pongas dos o mas parlantes en paralelo, el manejo de potencia debe ser igual en cada parlante y la suma total de la potencia de los parlante, tiene que ser mayor a la potencia del amplificador, para evitar roturas por excesos de potencia
Espero te haya servido mi comentario
https://www.bossaudio.com/manual/BE4000D_EN_UM.PDF
Dual Car Audio &... | Answered on May 29, 2019
Check all wiring/connections, fuses, etc. and don't forget the one on the back of the deck itself!
Dual Car Audio &... | Answered on Mar 19, 2019
YOU MIGHT TURN YOUR HEAD LIGHTS OFF
Dual Car Audio &... | Answered on Mar 10, 2019
What ohms are the voice coils, and what ohm rating is the amplifier you are hooking it to rated at?
Dual Car Audio &... | Answered on Feb 04, 2019
Hi there, in reality it does not work that way. The proper way is to contact the company that makes it and become a authorized service and repair person with the company which often inn wolves you paying for it, next after approved you need to buy the access to schematics from the company. Alternatively you can ask you question to get a better answer. You should also post pictures and picture of the circuit board where it connect, list you capabilities so I know what instructions to give, be ready to use a multimeter or a volt o meter.good luck https://www.6ya.com/mr.mike
Dual Car Audio &... | Answered on Jan 31, 2019
I have a Ford F-150 2001 and I'm trying to install xDVD8181 in it and I bought the accessorie for it from wall Mart and I have power to the radio but no sound what do I do
Dual Car Audio &... | Answered on Jan 29, 2019
Dual 15" Bandpass Sub Box Enclosure Plexi 3/4" MDF Car Speaker Logo
1 questions posted
Top Dual Car Audio & Video Experts
Ekse
Marvin
Marvin
Larry Tezekjian
Larry Tezekjian
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Dual Car Audio & Video
Most Popular Question
2 15 type r subwoofer 2000w alpine
  • Car Audio & Video
