I would try to start the unit with only the fan running at first. If it stays running then cycle on the compressor and see how it does. If the unit does not operate when compressor is turne on then we have to dig deeper into that.
Air Bocahttps://www.airboca.com > what-to-do-if-your-ac-has-...
Nov 14, 2022 - Additionally, a common cause of blown fuses (and trips to the AC ... on the fuse, you can inspect the access panel of your air conditioner.
"); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 62px;"> Rating: 4.7 · 285 votes
Missing: Fedders A6Q10F2A
Stack Exchangehttps://diy.stackexchange.com > questions > why-does...
Sep 7, 2013 - Which fuse is blowing? There are 4 common locations for fuses: main fuse panel for air handler, main fuse panel for condenser, local disconnect ...
6 answers · 1 vote: Long-term darkening of a fuse on a high-draw circuit like an AC is not unusual. How
very limited information generic answer look on the covers of the unit for your c line connection and check if your thermostat wires were connected if all are then you have a c line but not connected on stat if not connection at units then run a line to the stat
How do I tell the age of a Fedders furnace or air conditioner from the serial number?
Although the Fedders brand is used for window units nowadays, this encoding only applies to when they manufactured unitary (split) systems years ago. The second letter of the serial number indicates the year of manufacture (from 1966 to 1977):
A = 1966 B = 1967 C = 1968
D = 1969 E = 1970 F = 1971
G = 1972 H = 1973 I = (not used)
J = 1974 K = 1975 L = 1976 M = 1977
An ancient Fedders unit we recently inspected had the serial number AH11877, indicating that it was manufactured in 1973. The home was built in 1973, which provided a secondary verification of the manufacture date indicated by the serial number
https://www.manualslib.com/brand/fedders/air-conditioner.html
Usually the front is held on with screws on the sides of the unit. I would check behind the filter screen trim plate as well. I would be surprised if the front is just snap locked on.
You need to know why it's there. I'm guessing one put it there because of a reason, (no common outside, only one good wire, no 24 to power a board, SOMETHING). What and exactly where is it hooked up?
