20 Most Recent Sony VGN-FS740/W Notebook Questions & Answers
6answers
How to expand laptop C partition space?
You can compress the partition/disk to have more space, or you can use an external storage drive.
4/11/2018 8:07:37 AM • Sony VGN-FS740/W... • Answered on Apr 11, 2018
Video driver
Follow this link below to download appropriate drivers:Drivers
9/27/2013 12:58:03 PM • Sony VGN-FS740/W... • Answered on Sep 27, 2013
Mother Board is dead. Could you
My mecury board is running and swithes off by its self. what could be the problem
1/6/2011 9:42:10 AM • Sony VGN-FS740/W... • Answered on Jan 06, 2011
Vgn-740w sony vaio just installed w7 no
the drivers for your model are available for free download here:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFS740W&upd_id=1956&os_id=7
this driver is for Windows XP which was originally installed on your computer model. click the "download now" button and make sure to save the file to your DESKTOP so that you can find it after you download it. double click on the downloads' new icon on your desktop to start the installation.
NOTE: if you have changed operating systems from xp to vista or windows 7, you will need to hit the button that says "see all applicable models and operating systems" and download the appropriate driver for YOUR operating system.
8/23/2010 5:25:04 PM • Sony VGN-FS740/W... • Answered on Aug 23, 2010
Purchased 1g ram to add to my computer and now i
Hi!
First of all, check if the RAM module(s) sits firmly in the slot(s).
Now try this:
With the power cord disconnected and with no battery attached, press the power button several times, short pressings. Now reconnect the power cord and try powering up normally.
You can also try using 1 memory module at a time, with each one of the available slots in the laptop.
Pelu.
3/15/2010 12:10:10 AM • Sony VGN-FS740/W... • Answered on Mar 15, 2010
2answers
My laptop got virus so I reinstalled but I cannot
You can use the driver that you downloaded from the US site it is still the same, as your version of VIAO still uses English as default language.
1/18/2010 11:25:03 AM • Sony VGN-FS740/W... • Answered on Jan 18, 2010
After using the recovery DVD, my VAIO VGNFS40/W doesnt work.
When you start or restart your computer hold down F8 and go into safe mode and let it boot up. then just try to restart it and see if it boots now by itself or not. if this is still not the case put the recovery/repair disk back into the drive and boot from the DVD instead and repair the OS. One of the two solutions should fix your problem, if this is not the case get back to me.
8/2/2009 8:15:50 PM • Sony VGN-FS740/W... • Answered on Aug 02, 2009
VGN- FS740/W
u must install original sony windows by original recovery cd from ur laptop .
turn it on and push F10/F11 quickly then it goes to recovery from its hdd .
8/2/2009 12:00:55 AM • Sony VGN-FS740/W... • Answered on Aug 02, 2009
Recovery dvd
Sony does not offer the recovery dvd for download. You can actually burn yourself a repair disc, which you then can use to reinstall the OS.
Just follow the instructions here http://www.istartedsomething.com/20070929/vista-sp1-recovery-disc/ for your project.
But don't forget to back up your personal data first, otherwise it will be lost for good.
8/1/2009 10:04:47 PM • Sony VGN-FS740/W... • Answered on Aug 01, 2009
I'm trying to locate the
You can find it here
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C303556&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=38859786&stateId=0%200%2038865753
11/26/2008 7:20:05 AM • Sony VGN-FS740/W... • Answered on Nov 26, 2008
Service Pack 2 issues
For free sony support go the link choose the produce and chat for free
http://esupport.sony.com/US/perl/support-contacts.pl
Thanks for using fixya. Hope this solution may have helped you.
6/17/2008 6:04:00 AM • Sony VGN-FS740/W... • Answered on Jun 17, 2008
Service Pack 2 install
Are you getting an error message?
6/3/2008 4:52:56 PM • Sony VGN-FS740/W... • Answered on Jun 03, 2008
VGNFS740W
your power converter board probably failed its a common problem for that model, unless you are very proficient at repairs you would be better off going to a pro to fix it. my place is outside of lexington ky.
12/31/2007 3:52:12 AM • Sony VGN-FS740/W... • Answered on Dec 31, 2007
2answers
Need to replace the keyboard on the Sony VGN-FS740
Most keyboards are removed by first removing the top bezel that starts above the keyboard and often wraps around the lid hinges. There are often screws in the back side of the hinges. this bezel most often snaps into place and will need to be popped loose after removal of the hinge screws. It can be a little scary the first time you do it. when this is removed the keyboard usually will have 3 or 4 screws in the top edge and tabs in the bottom edge. A ribbon cable will attach it to the motherboard.
The keyboard can be found here. http://www.partstore.com/Part/Sony/Sony/VGNFS740/Sony/Sony/147915321/New.aspx
12/31/2007 3:49:05 AM • Sony VGN-FS740/W... • Answered on Dec 31, 2007
Want to upgrade from vista to windows 10
The Microsoft website will give details of how to upgrade and the costs involved, though buying the new operating system on hardware and performing a drive format and a clean new load could make more sense. A computer that previously ran Vista will probably be a few years old and therefore have a low specification so you could be disappointed with the performance when running Windows 10. I have a very old pc originally running Windows 95 that copes well with XP without perceptible loss of functionality for modest purposes, which makes no sense at all. On the other hand a relatively high-spec laptop I own needs a fair amount of patience running Windows 7. You have to try these things but the results aren't assured and it is a bit like making a wager with your cash. Might be more economic to buy an up to date machine.
11/23/2015 2:17:18 AM • Sony VGN... • Answered on Nov 23, 2015
An example of windows live id and password for virtua tennis 4 on pc windows 7 professional
You'll need to register/create a Windows Live user account so think up a simple username and password such as virtuaplayer@hotmailcom and 12345678 for the password.
2/2/2015 8:49:33 PM • Sony VGN... • Answered on Feb 02, 2015
3answers
How do i fix the distorted, halogram-like video pictures on my computer?
First of all, how old is your display? Second, how did that happen in the first place? Finally, was your display recalled because of inherent video artifacts like the one you're describing? You should check with your OEM before making any queries on sites like this.
2/2/2015 8:24:08 PM • Sony VGN... • Answered on Feb 02, 2015
How do i send photo files that are on my laptop without losing the pictures
Hi Irene - There are many ways to send photos and so I am assuming you are sending them by email. If this is not correct, please provide more info. Within your email program send a new message. In the new message, click on Attach File or Insert Picture. Which ever you choose, it will open a box that will allow you to locate your photo files on your laptop. Select the ones you want and they will be added to the email. They will also remain intact on your laptop. Hope this helps. Thanks.
1/20/2015 4:48:03 PM • Sony VGN... • Answered on Jan 20, 2015
Sony VGN-FS740/W Notebook Logo
20 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VGN Sony
  • VGN Sony
Most Popular Question
notebook sony vaio
  • Computers & Internet
