20 Most Recent Sony VAIO VGN-FJ170/B Notebook Questions & Answers
2answers
Dennythedon3003 is the latest spammer loser - what can be done? VGN-FJ170 forgot bios pass
BIOS passwords can be difficult to remove, Please click on this link and follow my instructions :-
http://www.fixya.com/support/r5876776-bios_power_password_removal
11/30/2018 11:37:48 AM • Sony VAIO... • Answered on Nov 30, 2018
Tengo problemas, con mi portatil VAIO VGN-FJ170 no puedo encontrar los controladores de video y camara motion eye. Por favor alguien puede ayudarme. Gracias
use el software system restore . vaya al panel de control.Use the system restore a una fecha que usted sabe que estaba trabajando, y reparelo. Si esto no resuel el problema, haga update driver de su suplidor de su computadora, Desintale el viejo driver corrupto e instale el nuevo. y trate de nuevo.God bless you
5/23/2013 7:18:57 PM • Sony VAIO... • Answered on May 23, 2013
I forgett the password Bios
http://mastermindit.biz/Unlock_Bios_and_HDD.php or http://www.unlockbiosrecovery.com/ can help you clear the bios password. Great service and very helpful.
9/23/2011 9:06:41 PM • Sony VAIO... • Answered on Sep 23, 2011
Deseo los driver de una
http://esupport.sony.com/perl/swu-list.pl?mdl=VGNFJ170
4/17/2011 3:56:01 PM • Sony VAIO... • Answered on Apr 17, 2011
Display failure for Sony vaio VGN-FJ170P
Please answer me this question
1.do you see the BIOS post message when you power on the laptop
2.Di you see the power led on .
please let me know and will help you out
Thanks good day
12/11/2010 2:21:45 PM • Sony VAIO... • Answered on Dec 11, 2010
Function key doesn't work, how to fix it?
Install VAIO Event Services (Notebook Utility) and restart the Computer.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFJ170B&upd_id=2002&os_id=7
6/26/2010 12:30:01 PM • Sony VAIO... • Answered on Jun 26, 2010
I need VAIO® VGN-FJ170/B Restore Disks
You can create your own disc from the Vaio recovery center.
If the computer is no longer booting up and the Vaio Recovery center is no longer accessible, you can call sony parts center to check if you can buy a recovery disc for your unit
parts center 8004887669
4/11/2010 1:53:54 PM • Sony VAIO... • Answered on Apr 11, 2010
Cooling fan not work
Its better to give to an expert for repair , but if you still plan to do it by yourself , then unscrew the back of the motherboard , before doing first unplug the Battery and unplug the Keypad with 14 screws to be removed. You will find the processor Fan to be replaced. You need to have the right tool to handle this. Good Luck!
1/29/2010 3:09:10 PM • Sony VAIO... • Answered on Jan 29, 2010
Its seems that my Vaio VGN-FJ170 is been draging RAM. really slow
1-Try installing graphic-cards driver from the vendors home site!
2-Install a Codec pack like k-lite
3-use VLC-player
4-If yor graphics use shared memory , it could be a result of memory module failure.
Best of luck
1/5/2010 1:55:51 AM • Sony VAIO... • Answered on Jan 05, 2010
I have a sony vaio vgn-fj170 notebook and I
If the Optical Drive icon is missing from Windows Explorer and has exclamation mark in the Device Manager, then it's required to edit the Registry settings pertaining to the CD/DVD Drive.
Follow the steps that are give below to edit the Registry settings to make the Optical Drive reappear:
(i) Please press the Windows key on the Keyboard and then press the "R" key while holding down the Windows key to open the Run dialog box.
(ii) Then, please type "devmgmt.msc" without quotes in the Run dialog box and click OK to open the Device Manager window.
(iii) In the HKEY_LOCAL_MACHINE folder, double-click the System folder.
(iv) In the System folder, double-click the CurrentControlSet folder.
(v) In the CurrentControlSet folder, double-click the Control folder.
(vi) In the Control folder, double-click the Class folder.
(vii) In the Class folder, click to select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder.
(viii) In the right pane, click to select the UpperFilters registry value, then press the Delete key.
(ix) In the right pane , click to select the LowerFilters registry value, then press the Delete key.
(x) Close the Registry Editor window.
(xi) Restart the computer.
Restarting the Computer will make the Optical Drive reappear.
1/2/2010 10:48:07 PM • Sony VAIO... • Answered on Jan 02, 2010
Unit does not turn on. i replace the battery and
Hello and thank you for using Fixya's services.
I have a couple of questions and some troubleshooting tips for you:
Questions: Is the splash screen coming on at all? Any picture or text right when you boot up? What Windows are you running (Windows XP or Vista)? Are there any lights on when you boot up or beeps? If so how many beeps do you hear?
First troubleshooting: If it boots up and is at least showing the splash screen (Sony splash screen or text) then it would be that the operating system is corrupt. This can be caused by several things included viruses, power surges or hardware failure.
The solution for this would be to take the hard drive out and slave it to another working desktop computer to retrieve your data. The attach the hard drive back on and reformat it (I can add specifics to doing this once I know the operating system).
Second troubleshooting: If you hear the operating system chime but do not see a picture and all the lights are on, then this would indicate that the back light on the screen is out. You can test this simply by hooking the laptop up to a monitor and see if you get a picture. If the computer screen shows on the monitor, then your back-light is out. If it doesn't show up then your video graphics card is out.
If the back light is out, it is easier to order a new screen (new or used) from eBay and just switch out (simple process and you can find a replacement for under 50 dollars on eBay). If it is the video graphics card, then you can also purchase one from eBay and switch out (a little tougher because you have to take the top of the laptop off). You can get assistance with this from the manufacturers website and pull specs for free.
Third troubleshooting: If you do not hear any beeps and the above solutions did not work. Then your motherboard has failed. This can be caused by surges or dust. You can purchase a replacement from eBay for a fraction of the cost and replace (this is tough and I am not sure if they have specs for this). You can do it yourself, just be sure and put everything back together as it was.
Fourth troubleshooting: To test the battery, take the battery out of the laptop and turn on with just the adaptor. If it boots, then the battery will need to be replaced. There is no way of testing the power adaptor but 85% of the time, this is the problem. Even if lights come on, the adaptor sometimes gets so overheated that it silently goes out but gives just enough power to make the lights come on. The power adaptor can be found on eBay for under 20 dollars and is cheap enough to replace (first) to make sure that is not the problem. The battery can also be found on eBay for under 60 dollars.
Please let me know if you have any questions and I will be glad to assist.
11/5/2009 4:09:06 PM • Sony VAIO... • Answered on Nov 05, 2009
0answers
I have a vaio vgn fj 170. When i put windows xp in portuguese the
BAIXA E INSTALA NA ORDEM QUE ESTA QUALQUER COISA TAMOS AQUI
Sony Shared Library for Microsoft Windows XP: http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFJ170&upd_id=1846&os_id=7
Sony Notebook Utilities: http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFJ170&upd_id=2002&os_id=7
Sony Notebook Control Device Driver: http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFJ170&upd_id=1775&os_id=7
7/15/2009 7:26:01 PM • Sony VAIO... • Answered on Jul 15, 2009
Sony vgn-fj170 labtop and my fn button is not working
I suggest that you install the Sony Shared Library first and then install the following drivers & software to resolve the issue. I have provided a link* to download and isntall the drivers & software: Sony Shared Library for Microsoft Windows XP: http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFJ170&upd_id=1846&os_id=7 Sony Notebook Utilities: http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFJ170&upd_id=2002&os_id=7 Sony Notebook Control Device Driver: http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFJ170&upd_id=1775&os_id=7
7/15/2009 7:16:18 PM • Sony VAIO... • Answered on Jul 15, 2009
3answers
LAPTOP OVERHEATS AND COMPLETELY SHUTS OFF
Have you cleaned it lately? If not that's what they sell those cans of compressed air for. With your computer off bloe the air through all of the vents you can locate to get all of tha accumulated dust that is blocking the airflow out of there!
5/25/2009 10:15:03 PM • Sony VAIO... • Answered on May 25, 2009
My sony vaio is not booting up and i cant recover it
Go into the BIOS of laptp and change the boot order like
hard disk
DVD
usb
etc.......
then save changes.exit
4/3/2009 8:36:05 PM • Sony VAIO... • Answered on Apr 03, 2009
Sony Vaio VGN-FJ170 USB Ports do not work.
are all your drivers updated?
and all your windows updates are done
hope i was helpfull
good luck
3/19/2009 12:37:21 AM • Sony VAIO... • Answered on Mar 19, 2009
Vaio laptop video upgrade
the webcam dosen,t work
12/28/2008 9:57:56 PM • Sony VAIO... • Answered on Dec 28, 2008
Sony VAIO VGN-FJ170/B Notebook Logo
33 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
tengo problemas con mi portatil vaio
  • Computers & Internet
