20 Most Recent
Kenmore 78802 / 78804 / 78809 Gas Kitchen Range Questions & Answers
Top burners will noty lite
Hello, this is a strange story.
I had this a few times in the opposite and then I found that it was a LPG cooker in stead of a natural gas cooker.
Did you buy this cooker second hand and did not use it before?
When this cooker is normally natural gas, then the nozzles are much larger then when used for LPG, as the pressure of LPG is much higher as for natural gas.
In that case you can change the nozzles for LPG use
Is this a dual fuel cooker with electric oven?
Kind regards, Dik
LPG Jets Cookers Ovens Hobs eBay
We have a Kenmore gas range ( 13 years old). We
Take a spray bottle and mix up a solution of strong dish soap and water... then spray down all of the connections in the gas line...with the gas turned on and the room well ventilated.
There will be bubbles from the leaking gas where the leak is. Proabably all you will need to do is tighten the connection that is leaking...
heatman101
Oven temperature fluctuating
Glowworm, Im assuming your model is a 790.78802500. If your husband is handy with a meter have him ohm out the sensor. It should show around 1091 ohms at 75 degrees or room temp. The preheat is programed so that the manufacturer can get the energy effecient label on the range and what ever perks they get from it. It actually should take around another 10 to 15 minutes to reach the set temp after it shows preheated. You can calibrate the oven by setting bake to 550 degrees. Then press and hold the bake pad again for 15 seconds or until a single beep is heard. Now you can adust temps up or down in 5 degree increments up to 35 degrees by using the slew keys. It will show in the display. Once you have the calibration done, press stop/clear. Catriver...post back
Kenmore Elite 790.99913804 gives an E0 39 error when trying to use the cooktop.
The E0 39 error on a Kenmore Elite 790.99913804 cooktop indicates a communication error between the user interface board and the power supply control board. This error can occur due to a faulty connection or damaged wiring between the two boards.
If replacing both the user interface board and power supply control boards did not resolve the issue, it is possible that there is a problem with the wiring harness or another component in the cooktop. It may be necessary to consult a professional technician to diagnose and repair the issue.
In addition, it is recommended to check the user manual for troubleshooting steps specific to this model of cooktop. The manual may provide additional information on how to resolve this error code.
Kenmore Elite 790.9505 Range
The Kenmore Elite 790.9505 range is a kitchen appliance designed for cooking and baking. It features a variety of burners, including a powerful 18,000 BTU Turbo Boil burner and a simmer burner for delicate foods. The oven has a large capacity and offers convection cooking for even baking and roasting. The range also includes a number of convenient features, such as a self-cleaning oven, electronic controls, and a built-in timer. Overall, the Kenmore Elite 790.9505 range is a versatile and high-performing appliance that can help make cooking and baking easier and more efficient.
What's the gas oven ignitor part number for a Kenmore Elite 790.3670?
The gas oven ignitor part number for a Kenmore Elite 790.3670 may vary depending on the specific model and serial number of your appliance. However, a commonly used gas oven ignitor for this model is part number 5303935066.
I would recommend checking your owner's manual or contacting Kenmore customer service to confirm the correct part number for your specific appliance. Additionally, it's important to ensure that you purchase a gas oven ignitor that is compatible with your Kenmore Elite model to avoid any potential issues or safety hazards.
Problem with kenmore elite gas range. Oven will not heat
It sounds like you may have a problem with the gas valve or the igniter in your Kenmore Elite gas range. The gas valve controls the flow of gas to the burner, and the igniter provides the spark to light the gas.
If the glow plug is coming on but the gas is not igniting, it could be a problem with the igniter itself or the gas valve. The igniter may not be producing a strong enough spark to light the gas, or the gas valve may be clogged or malfunctioning, preventing the gas from flowing properly.
You may want to have a professional technician take a look at your range to diagnose and fix the problem. It is important to have any gas appliance serviced by a qualified technician to ensure safe operation.
Kenmore gas range slow to preheat, takes 1 hour to get to temp.
There are several potential causes for a gas range being slow to preheat. Here are some troubleshooting steps you can try:
- Check the igniter: While the igniter may be coming on, it may not be getting hot enough to ignite the gas. Make sure the igniter is clean and free from any debris or corrosion. If it is dirty, gently clean it with a soft cloth. If the igniter is damaged or not getting hot enough, it may need to be replaced.
- Check the gas supply: Make sure that the gas supply is turned on and that the gas pressure is sufficient. If the gas pressure is too low, the oven may take longer to preheat.
- Check the oven temperature sensor: A faulty temperature sensor can cause the oven to take longer to preheat. Use a multimeter to test the sensor for continuity. If it is not working properly, it may need to be replaced.
- Check the oven door seal: A faulty oven door seal can cause heat to escape, making it difficult for the oven to reach the desired temperature. Inspect the seal for any cracks or gaps, and replace it if necessary.
- Check the oven igniter safety valve: The igniter safety valve is responsible for regulating the flow of gas to the oven. If it is faulty, it may be restricting the flow of gas, causing the oven to take longer to preheat.
If you are uncomfortable performing any of these troubleshooting steps yourself, it is best to contact a qualified appliance repair technician for assistance.
30" Kenmore gas range door is locked and can not be opened.
If your Kenmore gas range door is locked and cannot be opened, try the following steps:
- Check the control panel for any error messages or fault codes. If there are any, try to clear them by unplugging the range for a few minutes and plugging it back in.
- Check if the oven is in self-cleaning mode. If it is, the door will automatically lock and will not open until the self-cleaning cycle is complete. Wait for the cycle to finish and the oven to cool down before attempting to open the door.
- Try resetting the door latch. Turn off the power to the range for at least 30 seconds, then turn it back on. Press and hold the "Clear/Off" button for three seconds. This should reset the door latch and allow you to open the door.
- If none of the above steps work, it's possible that the door latch or locking mechanism is malfunctioning and needs to be replaced. In this case, it's best to contact a qualified technician to diagnose and repair the issue.
