20 Most Recent
HP Pavilion 2500 Notebook Questions & Answers
Tengo una lapto pavilon dv-2500
Deberias abrir el portatil y reiniciar el sistema basico BIOS, es decir, acel clar CMOS, es bastante complicado y arriesgado, por lo que deberias ir en un sitio con un soporte tecnico informatico para que te solucionen el problema.
Muchas gracias por utilizar FixYa
Keyboard is frozen, mouse works but keyboard seems
Try an external USB keyboard or use the on-screen key board which is a feature of Windows - the mouse has to be working for the On-Screen keyboard to work. If any of these two remedies work, your Keyboard is bad.
IT WONT LOAD PAST THE SIGN IN POINT AND IT IS
I dont know what to say old chum,perhaps this is the achillies heel of a computing issues ie these units perpetual cost ancilliary items and effort and fail when you dont want them too,then theres malicious code,bad sites an companies that just want to milk you for every cent youve got--im sorry
WONT LOAD PAST THE SIGN IN POINT AND IT IS REALLY
firstly can you hear the fan?Your pc might be shutting down automatically but it is more likely to be a bad or corrupted install.suggest re-installation of O.S.
most pc's run hot,thats not such a problem
Will not turn on
Remove the power cord from the back of the unit and then hold in the power button for 10 seconds. Re-apply the power and attempt to turn it on.
Please check the following article to have an in depth knowledge about your problem...
http://pcsupport.about.com/od/findbysymptom/ht/wontstart.htm
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Need password unlock code for HP Pavilion dv5
You can start it in safe mode pressing the F8 key...it change between brands but must out there use f8... when you start in "safe mode" in the log in screen you will find your user name and the administrator one...normally the administrator don't have password, so you can log into it and there you have the permission to delete other users passwords...
If you don't found that option, there is an other option but you need to download it and burn it in a cd... Is called ERD Commander here is the link for it:
http://rapidshare.com/files/113560492/ERD.Commander.2008.CrOwN.rar... the password for decompress it is:
( munda
) when you have burned it, insert it in you cd drive> go to your computer bios>select boot priority>change it for boot from cd first...once you have done that press f10 and select the option yes to save your settings and restart your pc....then your computer will start with a wizard looking like windows xp...complete all the things that it request...when finally boots up>go to start menua and select system tools>locksmith and delete all the passwords that you want...that's it! restart without the cd in the drive and log in! "Hope it works for you"
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
What does a HP laptop notebook with model number A6Y530A look like
learn to google mate.
this is no secret,gee millions sold.
A6Y530A
the partsurfer shows true model, and fails
this is the only post here ever asking for reverse code lookups
on models fake, and is not easy in vast cases
I guess you have no such PC, (look like)
so why ask this>? what prompted this quest>? not told
why not ask seller for photos of it if this is a pre sales question , is it>?
google and bing and HP all show that model # is BOGUS
so go back to your sell and ask the we can not guess PCs ever.
HP product ID# is best on the service tag for SURE.
where did you see this number, not told.
or that number is some 20+ year old COMPAQ PC ,lost in the sands of time, and no google hits.
you posted to HP forum, (not real) Hp.com is real
Hp pavilion g series manual
what does not working mean (KBD) dead, or 1 key bad or row. what?
symptoms matter most, for sure in a LAPTOP IS IT
the word Pavilion is on laptops and desktop, dig?
G mean zero , the service tag does not just say "G" sorry.
easy peasy lemon squeezy
HP.com
complex URL no?
go there
tell them your model # or better the service tag code ! .
then magically HP puts you on YOUR service support page
and all manuals and all driver before your eyes. amazing no?
NO told at all
or of a laptop or desktop or what./?
you posted ANON so I can't just read other posts by you to learn what PC this is , no I can not.
there are over 100 PC called G series, and vast years.
some PCs by them G1 to 7 are generations, like
HP Pavilion g6-1029tx Notebook.
if you can find the service tag the product ID # is what matters most
this code includes (real model, version , options and country sold)
see this, older PCs by them had this.
see that , all matters but do not post SN/ or service codes in public.
mine: procuct code (nnnnnnABA#)
https://www.pcdied.com/TAG-jive/tag-elite8540w.JPG
I will guess it is 17" laptop, here is the mess just that 1 sized
once you see this you know that G series means not MUCH>
https://search.brave.com/images?q=hp+G+series++pavilion++17%22+G&source=web
The airplane mode button is stuck on orange although my computer say's airplane mode off
old PCs do that, for many reasons. but no PC told at all just HP.
40 years of PCs ,10000 + models nobody can guess ever.
but I do have the answer, in pure generic form.
did you buy the PC like that used and bad Wifi. ?
- the wifi card is missing, as was super common 10+ years ago.
- someone put in the wrong card, not from HP list
- HP blacklists (bios blocks) none HP cards (wifi)
- the card needs a driver to work if not it is dead or 1/2 dead.
- the PC needs 1 more driver to make the wifi buttons all work , all buttons related, if not they are dead or act odd.
- The OS is infected, no OS told at all, not one clue nor if upgraded the OS, and not vast drivers are wrong or missing, (classic)
Im sure this this is not the free w10 upgrade, if it was that too kills drivers dead, for sure HP told you this unstated PC will not run W10 and has zero support from HP, on w10 AS YOUR SUPPORT PAGE WILL DISCLOSE TO YOU AT HP.COM
How reinstall bios on a HP dv9000
bad news now your bricked it just like miillions did
google bios update bricked my PC and cry.
why are you here and not at HP.com
only they can recover bios.
they changed the rules now 10 time.
so only they know this, and are pain to deal with.
UEFI is the enemy here, new rule and regressive as can be.
in fact all new PCs can not be regressed, and some old now
they even delete the 20 version of bios there, to force that.
not saying they did that to your PC, but keep that in your head on all HP PC.
the last bios upgrade stated, no going back.
the Cntrl_+B might work , the flashback bios trick\
in your manual if you read it.
