20 Most Recent
The Learning Company PrintMaster Gold 15 for PC Questions & Answers
Program won't open after installing
Do you get any error messages?
If not, try running system file checker to see if it's a windows based error. I usually see these types of lock ups when a DLL (Dynamic link library) file is corrupted or missing
Here is how you do it.
Simply go to the Run box on the Start Menu and type in: sfc /scannow
This command will immediately initiate the Windows File Protection service to
scan all protected files and verify their integrity, replacing any files with
which it finds a problem. Make sure you have your original Windows CD in case it asks for it.
This may take awhile so be patient.
Can't Print Notecards
I ran into this problem several times. The way I solved it was I drew an arrow on the side of the paper that faced in and up. When you look at the wrong placement, it will tell you which way to place the paper.
I would like to get rid of Babble.com YouTube and Twitter apps from my computer
The usual way to remove programmes installed on your computer is as follows (however you will need to be an authorised user or administrator):
- with the computer running click on the Start icon in the LH corner of the bottom menu bar
- then click on Control Panel
- then click on Programmes and Features
- in the list of installed programmes shown select the one you wish to delete
- then select uninstall in the menu bar above (you may get a window requesting you to authorise the next step)
- then click OK
- The computer should then delete this programme from your computer.
When this is completed you can delete the next programme you wish to remove by selecting it then selecting uninstall.
