20 Most Recent HP Compaq Evo n800c Notebook Questions & Answers
lots of reasons for this,
bad hdd, tops list.
XP from microsoft or HP? or from hackers?
is this disc real or from CD-r recordable made by whom?
does PC work ok with battery out, they love to short.
does BIOS work ok? seems yes.
did you take out the CD when the OS setup.,exe installer told you to?
the first big step in the install. that first reboot, take out the CD
or the cd can go back to step 1, run the CD, endlessly. doing that.
that Disk check, is in BIOS, right, and we all know its like a toy right?
I use knoppix linux live boot stick and run full HDD tests off it.
100x better that. and the smart status screen
if it SHOWS< no more spare SECTORS, that means the HDD IS AT THE END OF LIFE, as all HDD do. every one.
all HDD self heal , until the bandaids run out. and ends.
end of life.
if knoppic runs and disk test passes
then what is wrong, bad install media.
or worse, there is always worse on old Pcs like.
bad RAM
bad CD or DVD reader. (very common)
and even a weak power pack.. good, bad, or weak they can be.
ever run USB memory sticks, time to do that.
it installs the OS way faster and needs no working CD to do that.
no cd no drive, is best,
like new PCs, have no cd drive.
is yours with DVD drive? that too helps the helper.
looking in the hp parts surfer, DVD drive was an option
take the CD, make and ISO from it.
and ISO file then use RUFUS (free) to burn the ISO to USB stick
now boot that stick . to load XP
good luck with XP the virus magnet.... and zero support now for 3 long years.
HP Compaq Evo... | Answered on Aug 27, 2017
Hi, guy. Don't worry, there are many people forget their admin password/ lost admin password, and there is a popular solution for those who have been locked out by computer. For this solution, what you need id a second computer that can link to Internet and then free downloas Windows Password Recovery Tool 3.0 at http://www.windowspasswordsrecovery.com
With Windows Password RecoveryTool , you can create a reset CD which can be multiple used to reset windows admin password without erasing anything.
HP Compaq Evo... | Answered on Jan 15, 2013
You need a system disk first of all. Put the disk in the drive, turn the computer off then reboot. Watch the screen for which key it says to hit to change the boot sequence or boot order. Hit that key when it is shown. This is a one time solution that is only for the current boot process.
To make it permanent, boot the computer an notice what keys it says to hit to get into the Bios or System Setup. Hit that key when shown. You can change the boot sequence or boot order and make it a permanent change in the bios. The most common and best boot sequence is to have the CD drive 1st and the Hard Drive 2nd. Just make sure no disk is in the cd drive when you boot it up or you will get a error saying no boot record or system disk found.
HP Compaq Evo... | Answered on May 02, 2012
Windows is severely corrupted. Time to reinstall. If you have important files that you cannot lose then before reinstalling boot from a Linux Live-CD and copy the files to an external memory.
HP Compaq Evo... | Answered on Oct 29, 2011
log in to control panel then system devices . locate the usb logos and right click them . go to properties and update the drivers, make sure you have an internet connection.
HP Compaq Evo... | Answered on Jun 23, 2011
Run CHKDSK/F straight away and back up your data.
Fit a new hard drive and format then install your OS on it. Install driver updates from hp.com and finally update windows.
Restore your data.
HP Compaq Evo... | Answered on Feb 05, 2011
You can download the drivers from the Compaq/HPWEB support/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
www.compaq.com/country/cpq_support.html
HP Compaq Evo... | Answered on Feb 04, 2011
What is happening is that your laptop's BIOS is not "seeing" your hard drive, it is set to boot to a USB device and one is plugged in, or it is not seeing the necessary boot files (on any device) in order to boot up. You have one of a couple problems - either your hard drive is failing or you inadvertantly deleted one or more important files needed to boot up. Happens all the time.
In order to fix your laptop, you first need to determine if your hard drive is even being recognized. You need to enter the BIOS setup and see if the hard drive listed and what the boot order is. If you don't know how to enter the BIOS, then you would probably be better served to take it to a qualified technician who can get you going.
If your BIOS does not see your hard drive, then you drive has likely failed and will need to be replaced. If it is listed in BIOS, then you will need to repair the boot files. Depending on which version of Windows you are using, it is pretty straighforward. You simply insert your Windows boot CD-ROM and boot from that disk. Ignore the first "Windows Repair" option and select "Install Windows" (if it is Windows 7 then you will be asked for startup repair, select this.) Windows will then "see" your windows installation on the hard drive and you will be asked if you want to repair it - and yes, you do. After repair, your windows should boot. You may have to reinstall some applications as the registry may or may not be scrubbed. All your data files should be intact.
Remember, always back up your computer!
HP Compaq Evo... | Answered on Dec 06, 2010
remove the back cover (take screws off) .. inside you will see a circular (possibly taped) metal lithium battery, remove it for 30 seconds and then place it back) or better still, if the battery is connected to a connection, unplug the connector for 30 seconds then place it back
HP Compaq Evo... | Answered on Oct 15, 2010
It Is just The Problem Of The Software, Just Reinstall The OS.
HP Compaq Evo... | Answered on Sep 19, 2010
Remove it then insert again. if the problem as is use another hard drive... also check the set up setting of your unit.
HP Compaq Evo... | Answered on Aug 20, 2010
There's a break in the copper wires from the motherboard. This is unfixable, use the laptop as is or junk it.
HP Compaq Evo... | Answered on Jul 12, 2010
Hi imran_youtub it all depends at what time it shuts down unexpectedly. If it's after a while that means that your laptop is overheating. Make sure the CPU fan is working and if it is... get a cooling pad. Also download a software called HWM Blackbox http://download.cnet.com/HWM-BlackBox/3000-2086_4-10898732.html and take notes of the temperature. If it's working above 80 C...that's the problem. Please hurry because overheating will damage the motherboard. If it's really fast, that means the motherboard is in "short" and you have to take it to a repair shop. I hope this helps and dont forget to rate my answer. Thank you very much :D
HP Compaq Evo... | Answered on Apr 28, 2010
Please go through the BIOS Settings and sure to keep first boot priority to ur hard drive if is listed in the hard drive list.
HP Compaq Evo... | Answered on Apr 04, 2010
Right click on My computer then go to manage there you will find disk management in the left pane; find whether your portable hard drive is shown there. Create partitions if it is not created
HP Compaq Evo... | Answered on Apr 01, 2010
the obvious question:
is your windows legit?
if it's not you may have a corrupted windows copy, download another copy or buy one in ebay (they're getting cheap).
if it's legit. you have may have a hardware problem so more details may be required.
1. are you doing a clean install, any errors while files are getting copied?
2. do you have hardware that did not come with your computer installed or connected, make sure you disconnect everything and as your computer starts working, reinstall and test 1 piece of hardware at a time.
good luck
HP Compaq Evo... | Answered on Nov 22, 2009
HP Compaq Evo n800c Notebook Logo
50 questions posted
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
get around error message non system
  • Computers & Internet
