20 Most Recent GE 7 cu. ft. Chest Freezer FCM7DR Questions & Answers
Obviously, the compressor is not running. Confirm the presence of power to the compressor itself. If it is getting power and unit does not run, you have an open motor winding OR if you have a start capacitor the latter could be defective. Let's hope that you have the capacitor because they go bad and are a lot cheaper to replace than the compressor!
GE 7 cu. ft.... | Answered on Jan 21, 2014
Water could be from the lines freezing condensation on them then it melting over and over again. Not sure about the knobs.
GE 7 cu. ft.... | Answered on Dec 05, 2013
check first the convenience outlet or the main breaker reset if trip off or replace together the cord test it the continuity using ohmmeter also check the over load protector of the compressor replace if busted. also check the bulb if busted replace it.
GE 7 cu. ft.... | Answered on Feb 23, 2011
Good day,
Your idea was a good one, and it should not be neglected. The area your going to tape should be warm and dry. Best long term repair, would be to cut a small piece of aluminum, and epoxy it in place. The machine will need to be warm long enough for the epoxy to set, however, it should be a permanent repair.
GE 7 cu. ft.... | Answered on Nov 16, 2010
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
GE 7 cu. ft.... | Answered on Sep 12, 2010
that is the drainage hole where water can pass out from .
GE 7 cu. ft.... | Answered on Feb 20, 2010
silicone will work(ask for food grade)
GE 7 cu. ft.... | Answered on Aug 24, 2009
http://www.appliancepartspros.com/repair-help/general-electric-refrigerator-gsl25jftabs-repair/gsl25jftabs-frost-buildup.html
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
GE Freezers | Answered on Jan 02, 2018
The 6 or7 may be a setting number or a degree readout, which is a little on the warm side, should be around a -10 to-15.
Consult your users manual for details ,.Does not sound like an emergency, but keep monitoring it'
https://www.repairclinic.com/RepairHelp/Freezer-Repair-Help
This site may be of help.
GE Freezers | Answered on Dec 15, 2017
GE 7 cu. ft. Chest Freezer FCM7DR Logo
22 questions posted
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a GE Freezer Expert? Answer questions, earn points and help others
View Most Popular
GE Freezers
  • GE Freezers
Most Popular Question
ge freezer stopped working
  • Freezers
