20 Most Recent Friedrich D50C Dehumidifier Questions & Answers
Check the power to the fan motor or capacitor. One or the other needs to be changed.
Friedrich D50C... | Answered on Oct 01, 2015
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Friedrich D50C... | Answered on Jul 04, 2015
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
-0-0
Friedrich D50C... | Answered on Sep 26, 2011
Yes, it does make sense, depending on what humidity extraction level you have it set on. Set to high, it will will remove little to low condensation/humidity. Set it to 35% or if you have an analog model (no LED screen) set the humidity extraction knob on Maximum Also, be sure that the air intake filter is clean.
Thanks for choosing FixYa.
Friedrich D50C... | Answered on Sep 19, 2011
heatman101
Friedrich D50C... | Answered on Sep 14, 2011
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Friedrich D50C... | Answered on Sep 07, 2011
Depending on the time sequence you have this unit set to run, Fredrich's are designed so that the fan runs almost constantly, to keep the air moving. When it senses a rise in humidity above the level you have it set on, the compressor turns ON and runs until the level of humidity is lowered. This is especially true, if you are operating this unit in continual mode.
Hope this helps you and thanks for choosing FixYa.
Friedrich D50C... | Answered on Aug 15, 2011
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Friedrich D50C... | Answered on Aug 13, 2011
Generally, setting the humidity extraction level to what you want (Remember, the lower the percentage, the more humidity will be extracted) and not operating it in continual run mode will do the trick. Most humidifiers can be set to run in a 2 hour or 4 hour intervals. That means it will run as necessary for 2 or 4 hours and then turn OFF. It will turn back ON again, when the humidity level in the home rises above the setting you have it on.
Hope this helped you. Please let me know. Thanks.
Friedrich D50C... | Answered on Jun 04, 2011
The unit often has cavities that need to fill before it goes into the bucket... also your humidity may not be that high...so you may not be getting much water out of the air...
heatman101
Friedrich D50C... | Answered on Apr 23, 2011
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Friedrich D50C... | Answered on Jan 23, 2011
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Friedrich D50C... | Answered on May 14, 2010
Dave E. (Illeagle)
Friedrich D50C... | Answered on Jul 14, 2008
Friedrich D50C Dehumidifier Logo
22 questions posted
Top Friedrich Dehumidifiers Experts
Marvin
Marvin
WATCHING YOU
ray gallant
Are you a Friedrich Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Friedrich Dehumidifiers
Most Popular Question
fan run non stop compressor
  • Dehumidifiers
