20 Most Recent Philips 9400i Handheld Digital Voice Recorder Questions & Answers
Go to www.philips.com
Philips 9400i... | Answered on Apr 27, 2014
Connect it to your Mac and refer to User Manual.
Philips 9400i... | Answered on Apr 26, 2014
Time to send it to Phillips for service or get a new recorder,definite internal component failure
Philips 9400i... | Answered on Apr 07, 2010
Composite audio if you have the sockets, or Bluetooth if both have it.
Google
Bose (model) specs
and
Philips (model) manual
Philips Audio... | Answered on Aug 06, 2020
This can be due to a bad connection such as a cold solder joint or eventual failure of the display element.
Philips Audio... | Answered on Mar 31, 2020
I have a service manual pdf there isn't any way to attach it to this message. Give me your email address and I'll send it to you. Or if you have some other way to send it electronically we can do that.
Philips Audio... | Answered on Feb 05, 2020
Hi Darshan Ganesh, you can connect your phone to your Philips D573
You must connect the audio audio output of your phone (headphone output) to the Philips Auxiliary input on the rear panel
Hola Darshan Ganesh, puedes conectar tu telefono a tu philips D573
Debes conectar la salida de audio de audio de tu telefono(salida de auriculares) a la entrada Auxiliar del Philips en el panel trasero
https://www.philips.ae/c-p/FWD573_98/-
Philips Audio... | Answered on Oct 22, 2019
Here is a diagram for you.
Philips Audio... | Answered on Sep 30, 2019
You need to check the file format on music, windows media play does not support their format ((*.ra, *.rm). You can change the format to mp3 or .wav using other software.
Philips Audio... | Answered on Aug 24, 2019
I have a multimedia speaker DSP 3300.but I haven't the remote .Is there any way to operate it.
Philips Audio... | Answered on Jul 16, 2019
Google (Philips)(DVT1250)(manual) without parens.
Philips Audio... | Answered on Jul 04, 2019
What is the format of the drive? The Philips HTS6510 can only read USB drives that are formatted as FAT16 or FAT32. It can't read files from an NTFS drive. NTFS is the "new file system" for Windows but dates to Windows NT/Windows 2K or so. This is the default format for larger capacity USB drives since more files can be added per folder. See page 51 of the manual for the Philips HTS6510 for the file format specifications for USB drives.
If the file format is FAT16 or FAT32, try a different USB drive and check the current drive in another device. The USB drive may be damaged or may have lost the data it needs to find the files. All flash memory can fail with no warning. Replace a faulty drive. Alternatively, the USB port on the HTS6510 could be damaged. This can happen if too much current flows through the port. If the port is damaged, I don't recommend having the unit repaired unless it is under warranty (1 year). Copy your files to a CD and listen to the music or view the images from that media. The overall cost will be lower.
Philips has the manual on the product support page: https://www.philips.co.uk/c-p/HTS6510_05/-/support . The current link to the manual is https://www.download.p4c.philips.com/files/h/hts6510_05/hts6510_05_dfu_eng.pdf .
I hope this helps.
Philips Audio... | Answered on May 28, 2019
Philips 9400i Handheld Digital Voice Recorder Logo
Popular Tags
9 questions posted
Top Philips Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Audio Players & Recorders
Most Popular Question
download driver free
  • Audio Players & Recorders
