20 Most Recent KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher Questions & Answers
I don't know which Kitchenaid I have but it is
See if there is a start button on the right side of that control panel.
9/26/2017 2:42:43 AM • KitchenAid 24... • Answered on Sep 26, 2017
2answers
Kitchen Aid diswasher controls don't work
The Button is part of a switch control (all the buttons are individual switches) - take the switch block out of the door and test the button (switch)for circuit continuity, if it is OK, then the timer control may be the problem. My machine had progressive failures through the various cycles until most do not work and it wa the timer that was failing bit by bit.
9/6/2012 12:54:05 AM • KitchenAid 24... • Answered on Sep 06, 2012
The top sprayer or cleaning system doesn't seem to
1)check the boiler tank scaling formed.(clean the tank)
2)check water pressure.(solenoid filter get block)
1/7/2010 9:52:39 AM • KitchenAid 24... • Answered on Jan 07, 2010
Top shelf not cleaning
kenp, did the repairman check the screen where the chopper is located? If this screen becomes clogged with gunk, water will be restricted going to the center arm and you will either have slow or no roatation. He would of had to remove the lower spray arm, filter and accumulator assy. to get to this. I had one the other day with the exact same problem and the chopper screen was plugged completely. If your dishwasher is not working right, you have 1 year warranty, parts and labor. You have a case for them to come back. Catriver...post back
4/8/2009 2:42:53 AM • KitchenAid 24... • Answered on Apr 08, 2009
No water flow through dishwasher
No you need to clean out the spray nozzles with an old toothbrush etc both top and bottom and also clean out the debris filter below or at the heating element at the bottom of the washer. Then run a bottle of dryright etc. to help clean up the buildup in the machine. Then do this once or twice a year from now on and that washer should work great. Hope this helps.
2/14/2009 9:16:04 AM • KitchenAid 24... • Answered on Feb 14, 2009
Leaking Dishwasher Help!
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
12/12/2008 1:03:27 PM • KitchenAid 24... • Answered on Dec 12, 2008
KitchenAid Dishwasher Model KUDI25CHBL1. How do I get the screw out of the bottom without it spinning
It sounds like the water inlet valve has stopped letting water in. With no water the spray bar won't rotate as it is driven by the pump. Generic videos.
1/31/2023 3:37:15 AM • KitchenAid... • Answered on Jan 31, 2023
Kitchenaid dishwasher sani rinse won't turn on
Same issue here. WHAT WORKED FOR ME was simply unplugging the dishwasher for 15 seconds (no idea if 15s necessary), and plugging back in. Viola!
1/28/2023 4:36:49 PM • KitchenAid... • Answered on Jan 28, 2023
I have a small pin hole in the bottom of my kitchenaid dish washer which is stainless.. Can the bottom pan be replaced or does the hole need to be patched?
If the hole is small you can seal it with epoxy putty. Clean and abrade the area and after mixing the putty make sure it is pushed well into the hole and if possible smoothed over on the underside. Two types that will work.
J-B Weld Waterweld Epoxy Putty, 57-g ' Canadian Tire
https://www.canadiantire.ca > ... > Adhesives Waterweld Epoxy Putty allows you to make permanent repairs in moist or under water applications,Will fully cure in 60 minutes and will adhere to most ... Rating: 4.2 · ‎106 reviews
12/3/2022 12:50:57 AM • KitchenAid... • Answered on Dec 03, 2022
Kitchenaid KDPM604KPS dishwasher stops minutes into cycle
I couldn’t find any error code 2H but I did find an error code H2O. This code means insufficient water pressure. If the display reads 2H, it usually means the start delay function is turned on. The dishwasher will turn on in 2 hours if door is closed. This dishwasher is advanced. To understand all operations you should read the user guide or manual.
10/13/2022 10:19:23 AM • KitchenAid... • Answered on Oct 13, 2022
3answers
I have a kitchenaid W10311121b. No lights, water
Do a hard reset and it should work..if not then replace the control board. http://www.ehow.com/how_7488137_reset-kud101flss6-dishwasher-control-lock.html
9/3/2022 4:53:59 AM • KitchenAid... • Answered on Sep 03, 2022
KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher Logo
Popular Tags
22 questions posted
Top KitchenAid Dishwashers Experts
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Dishwashers
Most Popular Question
top shelf not cleaning
  • Dishwashers
