20 Most Recent
Sharp AR-M700N Copier Questions & Answers
Change toner cart and error f2-00
well this is normally toner bottle gear is tight or micro electronic card is defected which you can see on toner cartridge but if them ok check socket where this micro card pin goes if connections r fine and u replace developer did calibration but still same prolem then u need to check the board if u have tested main board where toner connector goes jus swap hope fully will be ok let me know
Call for services code : E7-80
Communication trouble
between the MFP control
and the scanner (MFP
control detection)
Communication
establishment error/
framing/ parity/ protocol
error
Follows the
communication protocol
specifications.
Communication error,
timing abnormality of the
communication data and
the communication signal
line
Code f2 40
In Lipi 6306 line printer "Checksum fault block 8".It is not going on offline.What should I do now.I have not faced this type of problem before.
ERROR CODE F2-31
F2-31 = Process Control Error.
This is usually just a dirty Image Density Sensor.
If you are able to remove the drum unit check that the Image Density Sensor is not dirty or blocked.
The IDS is number '7' in this image:
The error should reset just by switching the machine off/on. The machine will attempt a 'process control' Provided the sensor is OK the machine should work. If there is a large amount of toner dust around the drum and in the machine it would be worth vacuuming this out. Check also that you are using the correct toner.
Hope this helps
Sharp AR-M700N damaging fuser rollers
it sounds to me like you have some severe fuser thermistor and thermal fuse problems ...i would look into getting an entire fuser assembly sharp part number
DUNTW7305DS** last digits depend on your location and power supply
AR M700N copier jams... trouble code H5-01
h5-01 error is five consecutive jams in the fusingg section. P*C* gets you into dervice mode thenn 14 for trouble reset. then execute and restart. check the fuser pawls for dull edges and breaks. also check roller tensioning system on fuser.
I need part numbers for Sharp AR-m620 fixing unit cleaning rolle
The part number is DUNTW7305DS88, DUNTW7305DS80,DUNTW7305DS11, DUNTW7305DS15
Not really sure which one is right - I found the part number on
Precision Roller.com they have only one part number on there web site # H3164 It cost $595.00 if your not a vender.
