20 Most Recent
Friedrich QuietMaster Electronic SS15J30A Air Conditioner Questions & Answers
Im charging a friedrich CP08E10
This is a capillary system and the proper charge is critical. The only way it can be done is to evacuate the system and weigh-in the exact charge as specified on the unit data plate. It will show in ounces the proper charge. If you put in too much the next thing you will be doing is replacing the compressor. How old is the unit? The only reason it needs freon is that there is a leak. Might be cheaper to buy a new unit.
8/8/2011 6:25:39 PM •
Friedrich...
Answered
on Aug 08, 2011
Does not cool
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
8/14/2009 3:05:42 AM •
Friedrich...
Answered
on Aug 14, 2009
