20 Most Recent
Haier HPM09XC5 Portable Air Conditioner Questions & Answers
I bought this portable air
You have a manually controlled model that has been discontinue. However, Haier still supports this model and you can get an Owners Manual via email attachment, by calling their Customer Support Dept. 1-877-337-3639.
Hope this helps you.
Unit is leaking all over floor
Can you connect a pipe from the drain pan to a drain? This would get rid of the moisture within the room instead of just recycling it.
Leaking water
Very common problem with these systems. This depends on humidity in the air. Some systems have a setting that you can turn off the dehumidifier. The downside to this is it doesn't cool quite as well as humididty absords heat. The drain pan in your system is probably overflowing. You have a couple options, you could "hard drain" it to outdoors, empty the drainpan regulary, or change the air settings (this may not solve completely if you live in a humid area).
Haier mini split E7 and exterior fan not working
On a Haier Split system a E7 error is a failure of the outdoor inverter PCB and the outdoor power supply PCB. Both will need replacing. Looking around $600 for those parts. Plus fitting. The indoor PCB is very unlikely to be needed.
