20 Most Recent TCL LE32HDF3300 32 Inch LED LCD HDTV Questions & Answers
Thanks for posting this information. I simply wish to allow you to understand that I simply consider your website and that I notice it terribly fascinating and informative. I am unable to wait to browse voluminous your posts.
http://www.customerservicehelp.org/roku
TCL LE32HDF3300... | Answered on Apr 09, 2019
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
TCL LE32HDF3300... | Answered on Apr 28, 2016
This feature should be on your remote somewhere. Probably CC for closed caption. There may be a setting for visually impaired under that as well as hearing impaired.
TCL LE32HDF3300... | Answered on Feb 17, 2015
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Service mode entry, adjust and exit procedure to many popular brand TVs are given.
TCL LE32HDF3300... | Answered on Feb 21, 2014
from remot press menu > picture menu> contrast> 9735 then service code wil open u can select & adjust
TCL LE32HDF3300... | Answered on Dec 03, 2013
002,009,001.Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
TCL LE32HDF3300... | Answered on Oct 21, 2013
There is a short circuit in its main power supply regulator board. Check and replace damaged component/s at this board. Never put a fuse and switch ON the TV, until all the faults have been repaired. It might make things wrong. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
TCL LE32HDF3300... | Answered on Oct 17, 2013
try update your TCL TV firmware by current update version file from USB stick
https://electronics-tricks.blogspot.com
TCL Televison &... | Answered on Jan 03, 2020
Replace the power supply.
TCL Televison &... | Answered on Jun 24, 2014
TCL LE32HDF3300 32 Inch LED LCD HDTV Logo
20 questions posted
Top TCL Televison & Video Experts
john h
Andrew Taylor
Andrew Taylor
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • TCL Televison & Video
Most Popular Question
voice over tv tells me everything
  • Televison & Video
