20 Most Recent Sharp Projector lamp Projector Lamp Questions & Answers
Replaced new lamp in sharp pg-d3050 projector, but
then ,check the lamp or lamp ballast (integrated with the powersupply) Have a nice day! We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. Jerry Lampdeng Limited
9/18/2016 5:18:22 AM • Sharp Projector... • Answered on Sep 18, 2016
My sharp XV-Z90U was working fine except that it
mainboard is failed Have a nice day! We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. Jerry Lampdeng Limited
8/26/2016 4:13:32 AM • Sharp Projector... • Answered on Aug 26, 2016
How do you reset the
There are two common methods to reset the lamp counter on these projectors: Method 1: - Press the decrease volume button on the remote and then the increase volume button within 3 seconds. - The LED light on the projector will turn green. - Turn on the projector. Method 2: - Turn on the Projector. - Open the standard menu using the remote. - Then select "Setup" or "Service" depending on your projector model. - Then select "Reset Lamp Timer" hope this solution has been helpful?
7/19/2010 11:29:26 PM • Sharp Projector... • Answered on Jul 19, 2010
2answers
I have the Sharp XV-z90u and we just replaced the
Or you could test it with just a burner which would be even cheaper. LumenArc sell burners individually. Your problem could be a ballast as well.
1/21/2010 4:51:59 PM • Sharp Projector... • Answered on Jan 21, 2010
I bought a new lamp for my sharp XR-11XC.
have you reset the lamp timer yet? can't remember the procedure for that one exactly often hold power and down and left arrows whilst plugging in power. Check info on instructions that came with your new lamp.
1/17/2010 10:38:03 AM • Sharp Projector... • Answered on Jan 17, 2010
Recently I was using my xv-z90u, I started the
There is no problem here, the sharp projectors just do this until you enter the reset procedure. It comes on a sheet with your lamp. they differ from projector to projector. often involves hold down power and some arrows while plugging in the projector - that will reset the lamp timer and you will be away!
1/17/2010 8:08:28 AM • Sharp Projector... • Answered on Jan 17, 2010
I have a sharpPGF212X Projector that has an orange
Light path is out of alignment. It has to be properly adjusted. Do not attempt the repair, it is delicate and complicated procedure.
12/28/2009 3:26:08 PM • Sharp Projector... • Answered on Dec 28, 2009
Red/Oranage indication near on the from power
need more info. what model of sharp projector?
11/12/2009 7:31:14 PM • Sharp Projector... • Answered on Nov 12, 2009
How to reset the lamp of NEC MT1050NL projector without the remote
You can do this via the buttons on the case...just navigate via the menu and find the menu for lamp resetting. Regards Kevin Andreassend. http://www.iceav.co.nz [email protected] +64-9-4142348
9/9/2009 4:38:25 AM • Sharp Projector... • Answered on Sep 09, 2009
Projector image burn (retention)
first off, make sure you got the right lamp and it's from sharp, not a "lamp store". the quality varies. it could be burning hotter than it's designed for. second, you may need to reset the setting to factory default (through the menu options). third, you may need flash upgrade. you'll need to contact a sharp service center for that.
8/4/2009 6:34:21 PM • Sharp Projector... • Answered on Aug 04, 2009
Our Sharp projector Model PG-B10S is Flickering
the flickering could be the lamp, but as for the bluring: if it's pixelated, it's resolution. make sure the computer and projector have the same. if it's not pixelated bluring, it's an optical problem. either the lenses are dirty or misaligned.
8/4/2009 2:16:07 PM • Sharp Projector... • Answered on Aug 04, 2009
Sharp Projector XV-Z90 Flickering
the color wheel is dirty. It just need to be cleaned.
10/25/2008 2:59:38 AM • Sharp Projector... • Answered on Oct 25, 2008
3answers
Reset Lamp sequence for Sharp XGE-3500U
Hi there
I checked out the users manual and according to it you should be able to reset the unit by going into one of the Menu's subfolders.
5/1/2008 5:18:10 AM • Sharp Projector... • Answered on May 01, 2008
0answers
Sharp projector turns on and then cuts off right away - any ideas
Hi there
First take out the lamp and check for any signs of damage.
If you can't see anything check the Ballast ( Lamp's powersupply )
3/26/2008 1:22:40 PM • Sharp Projector... • Answered on Mar 26, 2008
Which reset code do I use after adding developer to sharp ar-5726?
https://www.fixya.com/support/t14696300-reset_change_counter_sharp_ar_5726
3/24/2024 6:44:11 PM • Sharp Office... • Answered on Mar 24, 2024
Sharp UX-105 Fax Machine. I am looking for a copy of the manual please?
Question edited for clarity, turned around, added CAPS, added the word 'manual'.Duplicate question should have been deleted but Kardoc has answered, albeit wrong model. Refresh page to see your question when you press 'Post Question'.UX-105 in Russian, or 510 in English, which is probably close enough.https://www.google.com/search?q=sharp+ux-105+manual..
3/22/2024 12:08:51 AM • Sharp Office... • Answered on Mar 22, 2024
Manual for a Sharp UX-105 fax machine please?
https://www.manualslib.com/products/Sharp-Ux-510-641495.html
3/22/2024 12:00:07 AM • Sharp Office... • Answered on Mar 22, 2024
Sharp EL-1197PIII. How to load paper in it please?
Question edited for clarity. Remove the curl out of the paper by running 6" across the edge of a desk against the curl. With scissors, cut the end 1/2" straight. Then cut a 1/2" off both corners at 45 degrees. Push the paper in the slot and press the Feed Button. https://www.google.com/search?q=Sharp+EL-1197PIII.+How+to+load+paper My instructions are better than the video, but shows the process well. ..
3/17/2024 6:09:42 PM • Sharp Office... • Answered on Mar 17, 2024
2answers
AR 5516 sharp printer is showing dotted triangle symbol
Hello, Just replace toner cartridge or refill the toner container with refillable sharp ar202 refill bottle or sachet. Remember to remove waste toner if you are refilling, right.
3/17/2024 8:56:33 AM • Sharp Office... • Answered on Mar 17, 2024
16 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
sharp xv z90u just replaced
  • Office Equipment & Supplies
