20 Most Recent
Creative Labs Zen Vision Digital Media Player Questions & Answers
My zen vision m 30 gig only comes on when plugged into the mains
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Describe your zen vision v0.0.15 Problem
My main problem is that I don't have one, unfortunately. It looks like a very nice unit, but I'm kinda strapped for cash, and can't afford it. I suppose if my answer is accepted, that would help.
Recovery mode
If you Zen player is frozen or not responding You can follow these steps to go to recovery mode:
Detach your player from the PC if it is connected, and turn off the player. If the player stops responding, you can reset the player. To reset the player, gently insert a thin object into the Reset hole located below the power switch. Press and hold the Play button while powering on your player. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up:
Scans the player and removes invalid links from its music library. Does not affect music files themselves.
Format (All):
It erases all content! Save a copy of your player's content before formatting.
Reload OS/ Firmware:
Erases your player's firmware. DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot:
Reboots the device.
You can follow any of these steps or all of them one by one to restore your device.
Hope this helps..
Freezing, constantly having to restart it. not
Hi if the player is freezing and you are having to restart it all the time try format the player and wipping it completely clean and re installing the firmware threw the creative software you can get from Creative.com web site. Then reload all you data on the player and see it it still freezes up. It it still freezes up after doing this then the HD is going bad and will need to be replaced.
If you need any more help, parts or your player repaired you can
contact me threw my repair service web page by e-mail, phone or off eBay
at firehouse7777.weebly.com Thanks
My Creative software mp3 players harddrive has an
Hi if your player is in recovery mode and want take the firmware or is acting up. You will need to run the HD threw some repair software outside the player and if that does not work the HD will need to be replaced.
Creative zen vision m 30gb
Hi your USB port is damaged or the USB cable is bad.
Problem of conecttion
You need install the driver of your mp3 in computer to make them paired perfectly
Creative zen not reconised
What you might want to try is to connect the USB cable to the device and an open port on your PC and let it charge and see if after it has a full charge if you can power it on without having any other problem. Or if after it has a full charge if it is recognized by your PC as a connected device. If it has a full charge and recognized by your PC you should be able to use it without having any problem. Another solution is to download the updated firmware software, run the firmware update check your device and see if the display shows the Creative Labs logo if so you are in the clear and it should work without any other action needing to be taken on your behalf
I was upgrading the firmware on my creative zen
Hi.
please do the following steps:
Do an hard reset by pushing and holding a paperclip into the reset hole, located at the bottom of the unit.
If that does not work, hold down the power switch to the left, and at the same time , while holding the switch, put a paperclip into the reset hole and then pull out the paperclip, and keep holding the Switch. When the Creative logo appears, release the power switch.
You will get access to the hidden menu. Chose reset, or restart the firmware update using the hidden menu options.
If still no luck, and you have a dead unit, contact Creative at the number listed on the user manual to get your machine repaired. If the Zen is less than one year old, you will be able to get it fixed at no extra cost, under Creative's warranty terms.
See uk.europe.creative.com/support/warranty
See also:
Zen Vision User's Guide.book
I have a creative zen vision:m 60gb. I bought it a
My Sansa e260, came refurbished with no program for it. I just downloaded one, but now my computer will not show me the contents of my Sansa? Is there a better way to get a program for my Sansa? I'm just incapable of removing/adding music to it at the moment, and it's frustrating!
Power surge on hub port
Buy a new hub...and make sure you plug it into your 1000VA UPS. If you don't have one of those....Call me...
I sell them for $120.00
727-823-6100
First down load
Try "media monkey" google it , download it (free) and away you go.
Zen vision m firmware problem
Greetings,
Lotsa people are having the same problem with the firmware updates. Go check for your warranty, the product was working fine before applying THEIR firmware update.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
