20 Most Recent TCL LE24FHDD20 24-Inch 1080p LED HDTV Questions & Answers
There are no Time warner codes for TCL tv's. You will have to perform a "code search"
1 Turn on the device that you wish to program. If you are programming a DVD or VCR player, then insert a media disc such as a DVD or VHS tape.
2 Press the device key on the remote once. This remote is capable of programming five devices, and each has its own respective button at the top of the remote. For example, if you wish to program a TV, press the "TV" device key at the top of the remote. The device key will blink once.
3 Press and hold the "Setup" button on the remote. The selected device key will blink twice, indicating it is ready to be programmed.
4 Enter "991" on the remote. The device key will blink twice again.
5 Aim the remote at the device you wish to program and press the "Power" button.
6 Press the "Channel +" button on the remote. Continue to press that button until the device turns off. Once that happens, press the "Setup" button to lock in the code.
7 Press the "Power" to turn the device back on and it will be ready to use
TCL LE24FHDD20... | Answered on May 31, 2015
open its sevice code.go to picture menu then come on contrast & press this code 9735.tv wil go to service menu here u can do what u want
TCL LE24FHDD20... | Answered on Jan 06, 2015
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
TCL LE24FHDD20... | Answered on Aug 02, 2014
To know more about these, you have to download the repair manual to this set. Try to download it by internet.
TCL LE24FHDD20... | Answered on Aug 29, 2013
try update your TCL TV firmware by current update version file from USB stick
https://electronics-tricks.blogspot.com
TCL Televison &... | Answered on Jan 03, 2020
Replace the power supply.
TCL Televison &... | Answered on Jun 24, 2014
It sounds that the main system control memory IC is faulty. Replace it and check. This is a very cheap to buy IC. Eventhough its cost and size is small, the function of it when the set is switched ON, is great. It is a very small IC, having only 8 solder terminals. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window
TCL Televison &... | Answered on Oct 12, 2013
TCL LE24FHDD20 24-Inch 1080p LED HDTV Logo
14 questions posted
Top TCL Televison & Video Experts
Lawrence Oravetz
john h
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • TCL Televison & Video
Most Popular Question
when turn autosearch starts after few
  • Televison & Video
