20 Most Recent GPX MW6815DT MP3 Player Questions & Answers
I think I would re-format the player. The format of the player must be FAT32 otherwise WMA and many other file type won't work.
GPX MW6815DT MP3... | Answered on Apr 11, 2010
I had the same problem, and found out a solution. The reason no more files fit even though there is room is that the File Allocation Table can only fit so many entries. Your's must be at the limit. What you do is create a folder under the main folder and copy files there. It should work.
GPX MW6815DT MP3... | Answered on Apr 26, 2009
For those that still use this mp3 player here are some things you need to know.
the gpx mw6815dt can operate as a media player or a usb storage device.
you need to change which state it is in via the System option.
Enter (Sys) from (Mode) go to (Online Device) enter (Mode) select USB Disk or Media Device. When you connect it as a USB Disk you will see all files not shown when connected as a Media Device using windows explorer. Also I suggest you make sure if you format the GPX you stay with the FAT 16 file system.
Note: DRM only works when the gpx is in Media mode.
If you have an SDcard installed you can access it via windows explorer or media player as a usb device only. With media player 11 you can still sync both the internal and sd drive with your library however you won't have drm options since your in usb device mode.
Note: in order to have both usb drives avaiable you need to use the Multi Drive option under (Online Mode) in the (System) menu, other wise you won't see the sdcard.
GPX MW6815DT MP3... | Answered on Oct 23, 2008
I am having the same problem. I already formatted it and it wont transfer music from comp to mp3. it says that the device is disconnected, which it isnt, or that the device has stopped.
GPX MW6815DT MP3... | Answered on Sep 03, 2008
well what i did was turn it on.in the main menu..go to the box that says MSC (music)..press mode..it should say please wait.then you should either have a screen with different icons..if not then the screen where the song is playin pops up..if that is what happens press the stop button, then the mode button taking u to that screen with all the different icons..Press the >> button until u get over to the delete all folder..press mode..in the top right of the screen it should say no...if it does press >> once to go to yes..then press mode..and if its already yes then press mode..then after that it should say empty card when you try to go play songs.
GPX MW6815DT MP3... | Answered on Aug 19, 2008
I had a similiar problem with my laptop. All I had to do was to update the drivers and now it works fine (it would not even recognize the card before). Hope this helps.
GPX MW6815DT MP3... | Answered on Nov 21, 2007
Disconnect the player reset the computer and try reconnecting it, if this fails you might want to try reinstalling the player after another restart when the player is unplugged!
GPX MW6815DT MP3... | Answered on Feb 02, 2006
when transfering files from your computer to the mp3 player arrange the files in folders, that way you'll have much less scrolling down to do, and the songs will be easier to find. in case for some reason you cant get the supplied software to arrange your files in folders look into other programs that support your device. microsoft, realplayer, winamp and other companies all have software that support many different mp3 players. good luck
GPX MW6815DT MP3... | Answered on Jan 19, 2006
This is a website for the soundbar.
https://gpx.com/in-home/home-music-systems/18-sound-bar-with-bluetooth-wireless.html
There is a pdf of the manual on the page
Regards
Geoff
GPX Audio... | Answered on Jan 08, 2020
Most of those types of screws only require a 1/2 turn to unlock.
GPX Audio... | Answered on Dec 11, 2019
What happens is that a mechanical system under the turntable pushes on a micro switch to operate the motor. Clearly either the mechanical system has moved out of position or the switch has. You take the bottom off the turntable and see what happens when you move the arm.
GPX Audio... | Answered on Oct 19, 2018
Google (gpx)(sp60)(manual) without parens for instructions.
GPX Audio... | Answered on Sep 10, 2018
Google (GPX)(D606)(manual) without parens.
GPX Audio... | Answered on Sep 01, 2018
Google (gpx)(KC 220s)(manual) without parens.
GPX Audio... | Answered on Aug 11, 2018
GPX MW6815DT MP3 Player Logo
Popular Tags
19 questions posted
Popular Products
Top GPX Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • GPX Audio Players & Recorders
Most Popular Question
gpx mw6815dt trouble
  • Audio Players & Recorders
