20 Most Recent Samsung UN60D6000 60 Inch 1080p Smart TV LED LCD HDTV Questions & Answers
Samsung un60d6000 tv no picture only sound?
the voltage is ok doo you have constantly 150 v if not led blocks is bad
3/9/2017 4:50:19 PM • Samsung... • Answered on Mar 09, 2017
0answers
Samsung has standby light, it blinks tone sounds no green light. Replaced t-con, power supply and control boards.
Hi Patrick, have a close look at your LVDS cable and screen ribbons for signs of failure or heat damage, and you could try to pull a picture from an AV output in various formats to see if it's the screen itself is failing in some way, regards George
7/13/2016 10:52:30 AM • Samsung... • Answered on Jul 13, 2016
Will not turn on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
5/22/2016 3:50:16 PM • Samsung... • Answered on May 22, 2016
Won't turn on..no picture..red light blinks constantly
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/ Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
4/10/2016 12:12:12 PM • Samsung... • Answered on Apr 10, 2016
After a thunder storm i have sound, no picture, the tv powers up, the back lights are on, should i suspect a bad lcd screen?
Something else is going on. The T-Con board has no other function than controlling the picture. If there is a separate board for the led drivers, I'd suspect that one. The main board controls the sound.
3/12/2016 8:12:34 AM • Samsung... • Answered on Mar 12, 2016
Screen is start fade with black half way down screen now sound good
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
2/25/2016 5:15:15 AM • Samsung... • Answered on Feb 25, 2016
Do 2.4GHz cordless optical mouse work with this tv
A wireless keyboard option isn't offered for this model, however if the keyboard and USB port automatically connect without needing a driver or additional software, it may work.
2/4/2016 8:11:50 AM • Samsung... • Answered on Feb 04, 2016
0answers
Can I do picture in a picture?
Yes, you can. It has quite a capable PIP feature. See here for the user manual, p144-146 and further. http://www.samsung.com/us/support/owners/product/UN60D6000SF .
12/26/2015 11:52:07 PM • Samsung... • Answered on Dec 26, 2015
60 inch Samsung has a line going across and right side of screen is dark
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
10/3/2015 4:56:53 PM • Samsung... • Answered on Oct 03, 2015
I cant watch youtube on my tv
It has to be connected to the internet and the settings have to be correct for it to communicate with the router.
8/12/2015 11:26:59 PM • Samsung... • Answered on Aug 12, 2015
How do I get Hbogo to work on my Samsung smart tv?
Get HBO GO did you pay your monthly bill?
4/4/2015 10:45:13 PM • Samsung... • Answered on Apr 04, 2015
0answers
Samsung UN60D6000 60 Inch 1080p Smart TV LED LCD HDTV Logo
59 questions posted
Ekse
Demonic-2011
Demonic-2011
View Most Popular
LE Samsung
  • LE Samsung
Most Popular Question
after thunder storm sound no picture
  • Televison & Video
