20 Most Recent Toshiba 37RV635DB Regza 37-inch Widescreen Full HD 1080p LCD TV w Questions & Answers
Toshiba instruction manual
www.retrevo.com/ Visit this site to download it. Gopakumar Gopalan Google
11/13/2015 9:13:40 AM • Toshiba... • Answered on Nov 13, 2015
WHY I HAVE GOT HARITONZAL LINES ON TOP OF SCREEN ON TOSHIBA LCD 37RV635D
sounds like the same problem as with most screens. it could well be the screen as gone
4/26/2014 4:29:03 PM • Toshiba... • Answered on Apr 26, 2014
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
8/25/2013 10:16:46 PM • Toshiba... • Answered on Aug 25, 2013
No picture on TV screen
Check its back light inverter board. Check its supply voltage. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
10/23/2012 7:07:46 PM • Toshiba... • Answered on Oct 23, 2012
Can I use wireless headphones with the 42HL67US
Good wireless headphones have "line in" cable with 2 RCA plugs, which must be attached to TV's "audio out connectors. If you have only "optical" or "coaxial" audio stream out, you must upgrade your "wireless" gear to accommodate those signals. Forget about "headphone" jack! It's a blast of the past!Thanks,Alex.
12/4/2022 1:02:47 PM • Toshiba REGZA... • Answered on Dec 04, 2022
3answers
My Toshiba 75u7880az LCD tv blows the 5A fuse as soon as its plugged in!
Hi, Please immediately stop using this device and send it to Toshiba for a repair or replacement. It's not normal for a tv to blow fuses like this and could be a fire hazard. Thank you.
6/29/2022 8:27:02 AM • Toshiba REGZA... • Answered on Jun 29, 2022
3answers
Only black and white image show in my Toshiba tv
I would try sing a TV converter and a digital converter and see if that fixes the problem.
4/9/2022 1:49:55 AM • Toshiba REGZA... • Answered on Apr 09, 2022
Need to unlock side panel on Toshiba regza 42AV635DB without remote
Without a remote control, you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. All the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check these sites too. http://remotesearch.blogspot.com/ https://elektrotricks.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops; as well as online shops. Visit the sites by Desktop computer and type in the brand name of your device in the search box at the right column. It will help you find the remote you have to buy. Mobille view has no search
8/30/2021 2:38:33 PM • Toshiba REGZA... • Answered on Aug 30, 2021
TV will not turn on. IS not connected to a computer
Some people recommend trying to update the firmware via USB. Instructions here, http://hubpages.com/technology/How-to-Update-Toshiba-TV-Firmware. If it is a model 32C120U, there is a known manufacturers defect. This issue is cause by defective main board because the main processor is not well solder to the PCB or the e-prom memory lost the software data. Some time you can try replace the eprom memory on the main board (cost of the e-prom $15) or re-solder with a hot air gun the processor but 90% of the cases you have to change the main board, the cost is around $30 you can find it in www.myshoptvs.com these guy are super. To replace the main board is easy and takes not more than 25 minutes. This could be your board here, http://www.myshoptvs.com/marketplace/4169-toshiba-32c120u2-main-unit-461c4q51l11-431c4q51l11-vtv-l40613-m6662.html
3/19/2016 4:04:33 PM • Toshiba REGZA... • Answered on Mar 19, 2016
My tv screen is blank
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/ Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
3/10/2016 8:45:29 AM • Toshiba REGZA... • Answered on Mar 10, 2016
2answers
The words "Retrieving data" keep flashing on TV screen, even during normal programs, how do I turn this off?
Corrupted software. Contact the authorized service centre. Electro help
11/18/2015 8:12:28 PM • Toshiba REGZA... • Answered on Nov 18, 2015
How to fix vertical lines on my tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
8/27/2015 6:56:35 AM • Toshiba REGZA... • Answered on Aug 27, 2015
Sometimes geting colour banding across screen mainly when switching tv on
8/13/2015 1:21:58 PM • Toshiba REGZA... • Answered on Aug 13, 2015
Dvd want play
-Let it play and just listen. Good luck and enjoy Mai
8/5/2015 7:34:50 PM • Toshiba REGZA... • Answered on Aug 05, 2015
How to connect to foxtel
contact foxtel as you will need a service provide approval and then they will talk you through the process. foxtel is a pay provider and not free to air.
7/25/2015 7:11:25 AM • Toshiba REGZA... • Answered on Jul 25, 2015
Tv will not turn on
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
7/20/2015 5:19:03 PM • Toshiba REGZA... • Answered on Jul 20, 2015
Message coming across the top of screen saying my T.v. not connecting to my router
Make sure the connections etc are all good. make sure the router is operating. You may have to turn off both TV and router and unplug from power supply for 10 or 15 mins. Plug back in and both should reset and connect.
3/8/2015 10:13:58 AM • Toshiba REGZA... • Answered on Mar 08, 2015
We had a power outage last nite now timer rec. light is blinking
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
2/24/2015 5:46:59 AM • Toshiba REGZA... • Answered on Feb 24, 2015
Toshiba 37RV635DB Regza 37-inch Widescreen Full HD 1080p LCD TV w Logo
6 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
REGZA Toshiba
  • REGZA Toshiba
Most Popular Question
no picture tv screen
  • Televison & Video
