20 Most Recent Avaya Eurostyle 18D Corded Phone Questions & Answers
What you are experiencing is loss of programming. Is this fixed? Could be the batteries need replacing....
Avaya Eurostyle... | Answered on Nov 02, 2016
To program a Caller ID Name Display button using remote administration on Partner ACS Release 3 or later systems:
  1. In the Partner ACS R3 System window, select Extensions. The Extensions window appears.
  2. Select the extension you want to program. The Individual Extension Parameters window appears for the selected extension.
  3. Select the Button Programming button. The Button Programming window appears for the selected extension.
  4. Optional - For new systems where no download is available: From the Phone Model box, select the arrow and choose Partner-34D, Partner-18D, Partner-18 Non-display, Partner/MLS-6 Non-display, MLC-6 Cordless, MLS-12 Non-display, MLS-12D, MLS-18D, or MLS-34D for this extension. The button layout for the type of phone you selected appears.
  5. Select the button you want to program. The Partner Set Button Programming Information dialog box appears.
  6. Select the Caller ID Name Display button.
  7. When you are finished, select the OK button.
  8. Repeat steps 5 to 7 to program other buttons for this extension.
Avaya Eurostyle... | Answered on Feb 22, 2016
I do not see this as a function. Here is a link to the manual: http://www.beatriceco.com/bti/porticus/bell/pdf/bsp/518457701_avaya_how_to_use_your_partner_phone.pdf
Avaya Eurostyle... | Answered on Mar 18, 2015
some corded phones do not have that feature look on the handset
Avaya Eurostyle... | Answered on Mar 13, 2015
The only way to restore the setting is through a Backup & Restore card plugged into the system. Also check the system batteries. This will keep power to system during an outage.
Avaya Eurostyle... | Answered on Nov 29, 2014
Are these call from the outside? If so, it sounds like the Night Service is turned on. If not and these are extension calls then the Do Not Disturb is probably on.
Avaya Eurostyle... | Answered on Sep 20, 2014
Log into System Programming by pressing Feature 00 then left Intercom button twice. Then press #101 and enter date MM/DD/YY. Then press Feature 00 to exit and save.
Avaya Eurostyle... | Answered on Sep 18, 2014
I do not believe it is an option to turn off the intercom. The only option I can see is to set up a Privacy button (Feature 07). You can turn this on and off as you need to. It would also help to know which Partner Release you are using.
Good day Laurel, in order to give more detailed explanation and to help you solve any difficulty; you can download the Avaya Phone System Manual which you can read at your leisure time. hope this works.
Avaya Eurostyle... | Answered on Jan 05, 2014
You put the call on hold that you wish to transfer. dial the extension of the person you wish to transfer to announce the call and then click the transfer button and add the two calls together.
Avaya Eurostyle... | Answered on Dec 08, 2013
http://dstech1.com/changing-time-on-a-partner/
Changing the time on a Partner system must be done from extension # 10 or 11. 1. At station(Ext.10 or 11) press feature, 0, 0
2. Press the left intercom 2 times
3. Enter # 103
4. Enter the correct time in 24 hr. format, for example:
* to set the time for 09:00 A.M., enter 0900
* to set the time for 04:45 P.M., enter 1645
5. Press feature, 0, 0
Avaya Eurostyle... | Answered on Jul 05, 2013
Shoot the mail man or get a dog.LOL:
Avaya Eurostyle... | Answered on Oct 29, 2012
Avaya Eurostyle 18D Corded Phone Logo
Popular Tags
73 questions posted
Top Avaya Lands Phones Experts
martin hogg
Ekse
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Avaya Lands Phones
  • Avaya Lands Phones
Most Popular Question
caller id partner
  • Lands Phones
